Question about Kitchen Ranges
When I cook or bake in my electric oven things are never done in the recommended cooking time. The heating element is working fine.
  • 943 Answers
Hi. thanks for the question. does the door seal properly. check that..sometimes the calibration will go off. what i tell my customers to do a small oven thermometer, that you hang from the racks . then try the oven at 350 degrees .then look at the oven thermometer . and see what the difference is. so lf ,the oven temp is a bit low .cook at 375. degrees. that will make up the difference . no parts needed. cheap fix. thanks the appliance doc
Posted on Sep 28, 2008
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
Smoke comes out of top when cleaning oven. Oven takes way to much time to cook. Oven does not cook evenly. Items cooked in oven are burnt outside and almost raw inside.
hello jjm... these ovens have two heating elements. when one is bad they still heat but they bake way too slowly. this is the problem here. the fix is to replace the bad element but in my repair service I always replace both heating elements since when one goes the other is usually not far behind.
Apr 28, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
The broil is the top element and the bake is the bottom with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
