Question about RCA RS2020 CD Shelf System
Rca rs2020 micro digital synthesized tuner
I cannot get my fm radio to go above channel 90khz. Once it gets there, it flashes to ch 1, then 2, then 3. I have unplugged it to hopefully clear the memory,but the stupid thing keeps coming back. How do I get it to clear so I can just listen to my fm and am(which works, btw)?? I have clicked every button on the remote hoping to luck out and get rid of this channel thing. I was looking for a users guide for this unit, cause I can't find the one I had--altho I'm not even sure I got one, it has been a couple years. Your help would be greatly appreciated
How to change the indicated voltage which is indicated volt adjustment
Where the power cord plugs into the unit look for a red slide switch. One side will say 220 and the other will say 120. Use a finger nail to change the switch to match your local power voltage.
Sep 21, 2015 | Panasonic 330 Watts 5.1 Channel DVD Home...
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
What is RF CH used for?
RF is used for Radio Frequency on your Qam tuner to break it down its the tuner like cheel 1-99 or 1-125 or digital RF clear Qam tuner so RF is your tuner respectivly. You would use this when you have a OTA over the air antenna or sraight cable meaning from wall outlet to tuner not wall outlet to cablebox.
I hope this clears up the meaning.
Thanks for using fixya.com I hope this was Very Helpful to you.
Dec 12, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Unable to program channels above #36
ON THE CABLE SETTING ALL YOU GOING TO GET IS #36 this is an old tuner . in those days there where never going to be 36 channels ! the thing your getting hung up on is the marketing of the 110 ch tuner how that works take73 brodcast chanels add 37 cable chanels and you get 110 ITS ALL MARKETING
Mar 25, 2009 | Emerson Televison & Video
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Only get about 4 channels
Make sure in the on screen menu that the tuner is set for CABLE or AIR depending on whether you have cable or an antenna. The channel frequencies are the same for ch 2 thru ch 13 but everthing above that is different depending on your source.
Hope Ya Fix It!
Feb 08, 2008 | RCA TruFlat 27F520T 27" TV
I only get about 5 channels
Hope Ya Fix It!
My radio off frequency
is this set AM and the recievers FM? if so there will be no way round the 'problem' BOB
Jan 09, 2007 | Cobra 19 DX IV CB Radio
Fuse
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Dec 06, 2005 | RCA RS2020 CD Shelf System
RCA RS2020 CD Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
