Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon MP780 issue on Mac OS/X
In-Use/Memory flashing & make clicking. Moved computer and now flashes & clicks. Printer not recognized now, removed & reloaded s/w. New USB cable, different USB slot, powered off/on and let set for long periods of time. Still won't install correctly as Mac isn't seeing printer to load drivers from network download or CD load. Nothing in fax or print memory that I can see.
  • grposey1 Oct 03, 2008
    "In Use/Memory" light flickers and machine makes clicking noise continuously. Memory reference shows no docs stored.
    Problem Solver:
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Posted on Oct 04, 2008
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
Tip
Canon pixma mp780 Drivers and manuals for Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma Mp780 photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads Mp730, but the actual page linked will be for your 780.
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer will read memory card, but i cannot access from pc
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannot scan with MP Navigator on MAC
Overview for MP780, see next page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444
1. Allow pop ups on the page.
2. Select your Operating System: Mac OS X.
3. Look for the drivers section: there's a scanner driver called
mp780osxsd12131ej7.dmg. Left click on the driver for more information. On the next page read the setup information and agree to begin the download. Finish the steps in the setup information for installing the required scanner driver.
Oct 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
Clicks and In Use/Memory Button is flashing
You have the phone line plugged into the wrong jack on the machine. The line from the wall should plug into the jack labeled "L". The other jack is for a telephone or answering machine.
Dec 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
What canon printers/scanner/copiers are compatible with imac 10.5.5. MP830 is certainly not!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12804#DownloadDetailAct
File Name and Description
MP780 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp780osxsd12130ej7.dmg
MP780 Printer Driver Ver. 4.8.3 (Mac OS X)
mp780osxpd483ej7.dmg
PIXMA MP750/780 ScanGearStarter Ver. 1.0 for Mac OS X
MP750780SGS10MX_EN.dmg
Drivers
MP830 Scanner Driver Ver. 12.13.0 (Mac OS X)
mp830osxsd12130ej7.dmg
MP830 Printer Driver Ver. 4.8.3 (Mac OS X)
mp830osxpd483ej7.dmg
Software
Easy-PhotoPrint EX Ver. 2.0.1 (Mac OS X)
eppexosx201ea8-2.dmg
08/27/2008
MP Navigator Ver. 2.2.3 (Mac OS X)
mpnosx223ej7.dmg
Easy-PhotoPrint Ver. 3.7.0 (Mac OS X)
epposx370en.dmg
Firmware
File Name and Description Version File Size Date Posted
MP830 Firmware Upgrade Utility Ver. 1.13 (Mac OS X)
fump830osx113en.dmg
Guides and Manuals
On-screen Manual for Macintosh
mp830osmosx100us.dmg
User's Guide
mp830_ug_us_v4.pdf
Easy Setup Instructions
mp830_esi_us_v1.pdf
Nov 20, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
244 people viewed this question
old marine
old marine
