How do i stop getting error nomber OX8OOCCCOE when trying to send email?HELP!!!!!!
  • 1 more comment
  • phol605 Sep 28, 2008
    I am new to computers and don't know what default folders are. Please send me step by step instructions on how to solve error number OX8OOCCCOE
    I need more guidance than "contact your isp server" If you can't or won't help me please advise and I won't bother you again.
    When I click on the web site you sent I get unable to contact website I would like to have you troubleshoot this problem.
    Sergeant:
  • 208 Answers
There are two ways you can get this error,
I am giving the examples...
ERROR Ox8OOCCCOE
The connection to the server has failed. Account: 'Talk21',
Server: 'out.talk21.com', Protocol: SMTP, Port: 25,
Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
GET THIS WHEN USING WRONG DIALLER
Server: 'pop3.in.Talk21', Protocol: POP3, Port: 110,
Secure(SSL): No, Socket Error: 10060, Error Number: 0x800CCC0E
So i want you to make sure these things,
Are your outlook account settings correct?
when you say you cant get online is it just your email or is it your internet as well?
If its just your email, i would suggest your account settings may not be correct.
IMPORTANT:
This is one peculiar reason ,
If you have downloaded any recent updates,( it may be either from MICROSOFT), that may could cause this problem too.
Try sending Email by turning off the WINDOWS FIREWALL.
If it works, then the update to the wirewall could have caused that problem.(you can use ZONE ALARM instead of WINDOWS FIREWALL).
But first make sure that all your account settings and your password are correct.
Hope my info solves your problem,
Thanx for using fixya,
Cheers.
Posted on Sep 28, 2008
    President:
  • 1,952 Answers
If your settings are correct, try changing your password. That is the
most common fix for this error.
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Sep 28, 2008
    they provide POP3
    or IMAP support, they should be knowledgeable about how to set up your
    account in Outlook Express so that it will work for you. If you are still
    getting the same errors about passwords, it could be that the Protected
    Stores files may be damaged on your computer. Depending on your operating
    system, see if this link helps repair any problem there:
    http://insideoe.tomsterdam.com/problems/...
    Try creating a new identity, then open Outlook Express in that identity and
    create the account in that new identity and test it. It may be that your
    existing identity is corrupted, particularly if it is the "Main Identity"
    created with an initial install of Outlook Express
    mohammed marika thambi Oct 07, 2008
    just click the below link..ur problem will solve
    http://www.tutorials-win.com/IE6Outlook/...
    thanks
    try this too yaar
    http://support.microsoft.com/?kbid=81351...
  • 1,879 Answers
OX8OOCCCOE means that OUTLOOK failed contacting your email server.
Configuring your email client (OUTLOOK) needs assistance from your ISP tech support as the information such as the name of the email server is required.
  • 10,594 Answers
Correct link of Ekse advised is Here
    Scholar:
  • 148 Answers
The error 0x800ccc0e is shorthand for "failed to connect." It can indicate
a busy server (one with too many connections to handle your request) or just
an offline server. Usually trying again 15-30 minutes later will solve the
problem. Might want to consider finding another ISP with better servicing
abilities.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 28, 2008
    problem.
    0R---
    TO finding another ISP with better FASTER CONNECTION & servicing abilities.
    FOR CLARIFICATION ARE YOU USING A DIAL-UP CONNECTION ON YOUR INTERNET? AND FOR A BETTER ASSISTANCE LET US KNOW WHAT THE ISP YOU ARE USING RIGHT NOW,,,
    KEEP US UPDATED ON THIS ONE,,,
    Genius:
  • 3,422 Answers
Checking mail at a "slow time" of the day would probably end in success, where checking mail during busier 'peak' hours would result in this failure. Is this a pattern you also see?The below quote from an MS advisor is from: http://www.mcse.ms/message909637.html
abilities.
While there are several issues problematic with dial-up access, you are probably seeing one prime example of it. If you have not contacted your ISP provider to address this, you might want to. They may have limited resources available for non-DSL connections - it's worth a try.
Your error hasn't appeared in any "hardware" failure support areas, so I'm pretty confident this is simply an overloaded ISP mail server with limited connections available for your access route.
  • 13,433 Answers
The code means the connection to the server has failed. double check your settings.
If your intrested I can try to troubleshoot the issue with remote support
by opening and installing the remote support program here
https://www.fastsupport.com/163875858
  • 11 more comments
  • Ekse Sep 28, 2008
    do you have a dial up connection(makes a phone call always on connecting) or a faster internet?(works 24/7) If you have a dial up, the remote support is not a good idea. Do you want me to troubleshoot / fix the issue with you by remote support? You can use the link I sent earlyer to do that. You need to open the page and install the customer module.
  • Ekse Sep 28, 2008
    I don't get it why my solutions get hidden at times.
  • Ekse Sep 28, 2008
    HEllo, can you see me?
  • Ekse Sep 28, 2008
  • Ekse Sep 28, 2008
  • Ekse Sep 28, 2008
  • Ekse Sep 28, 2008
  • Ekse Sep 28, 2008
    You will need to copy this link text into a new browser window
    Or remove the fixya address from the front of it.
  • Ekse Sep 28, 2008
    Sorry for the extra comment, I was fustrated with the system, not showing my solutions.
    Simply open a new webpage and type in it ...https://www.fastsupport.com/163875858 exactly without the dots in the start.
  • Ekse Sep 28, 2008
    this should work also www.fastsupport.com/163875858
  • Ekse Sep 28, 2008
    The support session has timed out, I have opened another session for you, if your intrested
    http://www.fastsupport.com/299086718
    that link should work perfecly.
  • Ekse Oct 03, 2008
    have you receaved my emails I sent you?
  • Ekse Oct 05, 2008
    Hello? I sent you two email the other day, hows it going is the problem solved? If you need my assistance please comment here or send me a email at nikoht@gmail.com and I will troubleshoot it with you. Note that Im leaveing on holiday next wednesday and will be gone over 1 1/2 weeks.
  • 4,472 Answers
First of all do all your emails go to the default folders? Also are these folders very full? You can corrupt folders by overfilling. It is best to create a new folder and move e-mails to these folders.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 28, 2008
    This mean the connection to your e-mail server failed. How long have you been having this problem for? It is possible your e-mail servers are down.
    Thanks,
    Lee
  • Lee A.
    Lee A. Oct 15, 2008
    Once my questions are answered I can attempt to assist you further. Have you tried a different e-mail provider to test if it is on their end and not yours.
    Thanks,
    Lee
Why does My quick books premium shuts down after I email invoices quite often?
QuickBooks may display errors or stop responding when sending email then try for this solution by Intuit QuickBooks displays an error or stops responding hangs or freezes when...
and if need any technical guidance while working with problem follow Intuit Help .
Sep 04, 2014 | Computers & Internet
I HAVE CHANGED MY DEVICE ANDMY PHONE NOMBER HOW CAN I SEE MY EMAILS?
Go to settings then choose the email / sync option and add account, which would be your email address. You are actually setting up the new phone to your email account.
Aug 31, 2014 | Apple iPhone Cell Phones
Pls help me.i have the problum exeeded the allowed nomber off the attempt registerstion my nomber 0096590930405
You have exceeded the allowed number of attempts to register your account Please contact support at www.fring.com/help .. Pls send me registration code sanjupallikere@gmail.com my numer +96590930405
Jun 11, 2013 | fringland fring
When ever i create facebook account isee this after i continue my work says"your account is temporarily locked then say like phone nomber vertification because i am somalia and i dont get sms
either someone has tried to hack ur id or u hv used sm unknown app to login to ur account. so now ur account is temporarily locked for ur safety. now u need to verify ur idntity to facebook.this can be dn by either msging on phone or msging on ur email.
hope this will help u.
Jan 26, 2013 | Facebook Social Network
My facebook security code nomber
Pless secrurity code nomber.pless send mayur email account
Sep 27, 2012 | Facebook Social Network
When i try and forward a mail i get the following erros msg: 'Error sending message".... can you help? thanks Sandy
Normally we get this error when the EMail which you are trying to send has an Huge attachment attached to the mail. Clear all the mails and then try to send out a mail without an attachment and then check if you get the same errors.
Dec 31, 2010 | Yahoo Mail
Email error
i went on a forum and was told to do an msn virus scan which i did and it cleared it thanks.
Feb 20, 2008 | Computers & Internet
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
