My sd card is jammed in my laptop - Computers & Internet
  • 45 Answers
Try thin pliers. Make sure you have a copy of any important data on the card first, just in case.
Posted on Sep 28, 2008
Jammed sd card in d40x
You just try the SD card pull out by tweezers. first push it once and then pull by a sharp tweezers,
Aug 29, 2012 | Nikon D40x Digital Camera
Where to insert sd card
Normally the sd card slot will be on the side or in front of the laptop if it has that option. Not all laptops have sd card slots.
If your laptop does not have the sd card slot, then you can purchase a sd card reader that plugs into your usb port on the laptop for less than $20.
Try Tiger Direct at: http://tigerdirect.com
Below is a multiformat sd card reader for $9.99 at Tiger Direct.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=186067&CatId=2825
Also your camera might have come with a cable that plugs into the camera and the other end into the laptop's usb port. Once you have the cable connected, turn the camera on and the computer will recognize it. You can then search through the camera folder for the pictures or videos. If you use this method, you leave the SD card inside the camera.
May 20, 2012 | Computers & Internet
Laptop wont read sd card
You do not say, but before ejecting an SD card you should use the Safely remove hardware feature. If you do not do so you may damage your SD card, and you run into problems such as you describe.
Apr 06, 2012 | Dell Inspiron Computers & Internet
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
My sister pushed a sd card in my laptop in the wrong slot and is jammed. it is in the wrong slot. it is pushed back and it is not moving any because it is actually jammed.
can you read if it says sd micro on it if it does its good also check in my comp. and look to see if you see any pics , if not the its the wrong one and youll have to just pull it out, might mess up the sd card or not its the only way besides opening it up.hope that helped
Jun 26, 2009 | HP Compaq Presario V2000 Notebook
Sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Apr 21, 2009 | Computers & Internet
The sd card is stuck in the slot and wont come out
You tried to put a Sony Memory Stick into an SD slot? It will probably need as much force to pull it out as it took to jam it in there!
I'd power off, and start with tweezers... if that doesn't work... i'd break out the needle-nose pliers. You may break the reader while trying this... but a card reader is all of $10-20... and you're kinda stuck anyway. ;o)
Apr 19, 2009 | Compaq Computers & Internet
K JAM
that happend to me once, i totally freaked out.... try turning it completely off, remove the sd card, then turn it back on.
once your phone has finished booting up (and all programs have finished loading), put in your SD card.
If that doesn't work you could always hard reset the phone (sometimes that fixes it)
Jun 25, 2008 | i-mate K-jam Smartphone
Problem with micro sd card
Does the micro SD card have a lock/unlock slider for write protection?
Is it a high capacity microSD not supported by imate jam, and have you already formatted the microSD?
Mar 14, 2008 | i-mate JAM Pocket PC
SD Card Jams Into Device, Doesn't Come Back Out
There is system that locks the card in the card slot,it might have jammed or broken.
Thanks
Apr 29, 2007 | Palm Tungsten E2 Handheld
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
