Question about Cameras
I have a deo 3300 mp3, mpeg4 digital camaera. I used it to record my class one day and now it's not even turning on.
  • 2418 Answers
SOURCE: I have no manual & can't even turn on my
You do not mention the model number. What I have found so far is it may have been manufactured for Radio Shack. You may try their web site or contact them for a manual.
Posted on Jan 23, 2011
Card error
Is this the card you always used, or did you recently buy a new card?
Because you can use MMC cards and SD cards. Most SD cards you now buy, even the 2 GB ones, are SDHC cards and they are not compatible with your camera.
You should try to get an SD card. They used to make SD cards up to 4GB, but as I said, now they already make 2GB SDHC, So look careful when buying a memory card.
If it was the card you always used, try to get all pictures from the card, using an external memory card reader on your computer. Then in the camera do a format, before you continue.
If it does not work, try an other card. SD that is.
Mar 01, 2014 | Aiptek PocketCam DV4500 Digital Camera
If it doesnt record any sound with its videos,then how can i hear them
Most microphones on the camera may be too far away. So, its better to add voice or music on the computer to your movie from the Vivicam 8225 camera, using mpeg4/h.264(mjpeg+MP3)..
Dec 16, 2010 | Vivitar Vivicam 8225 Digital Camera
Record MPEG4 or MPEG2 motion video
The SV-AV100 records both MPEG2 and MPEG4 motion video. The SV-AV50 and SV-AV25 record MPEG4 motion video only. The SV-AS10 does not record MPEG4 or MPEG2 motion video. It can only record QuickTime™ Motion JPEG.
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
Difference between MPEG2 and MPEG4
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). * FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. * NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher.
MPEG4, MPEG2 - play back
MPEG4 motion video can be played back with Windows Media Player 6.4 or later. MPEG2 cannot be played back in Windows Media Player. Files created with our D-snap Video Cameras are designed for playback with the included MediaStage software and our DMR-E100H DVD Recorders.
Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
Cameras Logo
147 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
