Toshiba TP50 G60, blinkin red light, no picture no power. Had a power outgage and TV stop working. When you turn on TV it makes the noise of the TV comming on but not happens. Any Suggestions on what to look for? Your helop will be greatly appreciated
5 Suggested Answers
  • 3 Answers
SOURCE: Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Posted on Apr 09, 2008
SOURCE: toshiba blinking red light
MI TELEVISON PARPADEA LA LUZ ROJA Y SE MANTIENE EN ESTADO DE HINBERNACIóN
Posted on Sep 28, 2008
smarthome2
  • 1114 Answers
SOURCE: Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Posted on Jul 07, 2009
  • 90 Answers
SOURCE: I have a panasonic Pt-50LCZ70 TV.
I would suggest replacing the Lamp
Posted on Jul 09, 2009
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
My tv power light is blinking and the tv wont turn on.
To resolve this problem, follow these steps:
  1. Make sure that the power cord is firmly connected to the wall and the TV.
  2. Make sure that the cables connecting the TV to the various video sources (cable, set-top-box, DVD player, VCR, etc.) are all firmly connected.
  3. Make sure that the source you are trying to watch is turned on and/or providing a signal.
  4. Turn the TV off, and then on.
  5. Press the Source button on the remote, and cycle through the sources.
If this procedure does not resolve your problem, most likely the power supply is failing and you need to get your TV serviced.
Jun 01, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Jun 27, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
