Question about Whirlpool Washing Machines
Whirlpool washer stopped spinning 2 days ago. water drains fine.
  • 943 Answers
Hi. thanks for the question. the motor drive coupling is the part you need .It drives the transmission.about $25.00. you have to remove the cabinet .To do so .2 screws at the end of console, by the top .Remove them .Lift up console. 2 Brass clips remove them. disconnect wireing pull cabinet towards you .remove the pump disconnect power to motor. remove the motor . replace the coupling. thanks the appliance doc
Posted on Sep 28, 2008
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
I own a whirlpool top loading washer - under 2 years old. it stopped draining water and spinning. replaced the timer and now it works fine, but now when the washer finishes spinning, the agitator stops...
depending on your exact mode;
sounds like a brake, or a clutch
those are really only two parts it could be
on the whirlpool the brake is part of the transmission on the direct drive
Oct 15, 2009 | Washing Machines
I have a whirlpool duet. I had washed 8 towels 2
To get inside the machine for a look, you have to take the back panel off,
1. Pull the plug
2. Turn off and then Disconnect the HOT and COLD water hoses at the machine
3. Remove bottom, side and all but 2 top corner screws from the back panel (all around the outer edges only) then supporting the panel, remove one corner screw, let the panel down on that side, then remove the other.
4.Remove panel
5. Grab a light, look inside.
My guess is that the spinning, wobbling drum worre a hose thru.
Good Luck!
Hint: Put all the back panel screws in loose, all the way around... then tighten them
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx6 1200 express - brand new
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Mar 14, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Maytag neptune too much water, will not drain, door won't unlock
you may have something stuck in the pump a sock or a dish towel something small. you will have to get to the pump,,,thats why it wont drain or spin out it cant.
Jan 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
