Question about Home
Kohler one piece part number 1013282
Just replace the fill valve for kohler one piece andthe fill valve sprays a stream of water out of the top and onto the undersideof the lid is that supposed to happen? looks like photo below
Put on your rubber gloves so it doesn't slip. Grasp the blue nut that is attached to the copper tube then twist the white fill assembly until it clears the notches on the blue nut with a "click". You can now remove the assembly.
Install the new part in the same manner.
Posted on Feb 25, 2010
How do you replace a Kohler 1013282 fill valve assembly? Is there a manual anywhere I can download? Thanks, R. Low
Posted on Sep 10, 2009
    Novelist:
  • 171 Answers
Hi kayela,
I'm Harvey the Master Plumber.
Your question is: Just replace the fill valve for kohler one piece andthe fill valve sprays a stream of water out of the top and onto the undersideof the lid is that supposed to happen?
For some reason I can't seem to get the picture up. Nevertheless, the answer is no, it should not be leaking. Did you take a picture of the original before removal? Do you still have the original? Look carefully at the diference between the two. Make sure it's an exact duplicate and isn't missing parts. These one piece toilet parts are expensive but the suplier sometimes makes mistakes. You can only solve this problem if they match.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Jul 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Feb 06, 2010 | Kohler - Toilet - Two-piece - Highline -...
K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Sep 13, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Home Logo
1,818 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
