Question about HP DeskJet 940c InkJet Printer
HP Deskjet 940c keeps saying it's out of paper, won't print
My HP Deskjet 940c has started showing an error message that says it's out of paper and it's not. I've shuffled it and added to it but there's paper. It doesn't print anymore because of this. Sometimes when I turn it on in the morning, it automatically will print what I wanted from the day before. Can anyone help me. I liked the printer alot til this happened. Thanks
  • aratamom Oct 15, 2008
    I also have the same problem! Not sure what is wrong or how to fix it.
  • Cindi108 Oct 27, 2008
    I decided to take my printer to work to have my friend look at it. When we plugged it in there it worked fine. I brought it home and there is no more problem. Maybe it just the old, "unplug and replug" that did it. It's worth a try. It worked for me so far. Thanks for the posting and the help. Great site.
I have the same problem. In the error message box is a Cancel button.
If I don't click the Cancel then the print goes through just fine and I click Cancel when the print is finished.
Posted on Oct 27, 2008
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Every picture I print has striations through them. My pictures all look like they have been printed on corduroy paper. I am using an HP deskjet 940c. Any ideas?
Hi
The printhead of your color cartridge is clogged
or is near to end
you need to replace the color cartridge or refill it (cheaper method)
check here how
Jan 19, 2011 | HP DeskJet 940c InkJet Printer
My HP deskjet 940c has been out of use for a while and I just started using it again. It now prints like have of a page, stops and continues the rest on another piece of paper. Why and how do I fix it?
put a single paper at a time when u give a printing command. also use good quality papers. Adjust the size of the tray.
i hope this would resolve the problem
Aug 02, 2010 | HP DeskJet 940c InkJet Printer
It doesn't print. The message doesn't seem to go
open the printer lid and check that the cartridges start moving towards the left side and they will stop in one of the "sad faces" then replace the bad cartridge corresponding to that "FACE"
Mar 09, 2010 | HP DeskJet 940c InkJet Printer
My hpdeskjet 940c wont accept a 4X6 photo paper It tries but the paper doesn't slide through
Print a test page only in black. If little to no black shows, you need a black. If your color cartridge seems full, only get a new HP black ink cartridge.
Oct 03, 2009 | HP DeskJet 940c InkJet Printer
Paper keeps feeding thru w/o printing. Prints a couple of lines jumbled (not what's on screen), throws it out and takes more paper.
Try uninstall the printer drivers and download then install the latest version. This blank paper printing with random "symbols" are caused by incompatible drivers.
Jun 23, 2009 | HP DeskJet 940c InkJet Printer
The error message is ?Print catridge cradle cannot move?
Removed and realigned print Cartridge which was not firmly fixed.
Jan 29, 2009 | HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 940c InkJet Printer Logo
118 people viewed this question
Ben Johnson
