I already tried reinstalling the software
I checked all the cables,it's all connected
Copy & Print well, just the scanner is the probs..
It always says "there is no communication between scanner & computer".
Pls. help...
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
271
I guess u guys have to contact the cannon ..helpcenter
I need CANON PIXMA MP 160 drive
Scanning can be performed with the MP Navigator software. Please open the MP Navigator from your Desktop or the Canon Utilities listing of the Start Menu (Windows) or Applications folder (Mac).
Hope this helps you.
i cant engage scanner
When I scan, an error comes up on the monitor screen " Cannot communicate with the scanner.Cable may be disconnected or scanner maybe turned off. Check status. Scanner driver will be closed. Code : 2,155,0
SAYING IT CANT FIND CAMERA
Scanner diconnected,Same as the others
I have the same problem. All of the cables are connected and the software has been uploaded. The printer works perfectly and I can copy the document as well however when I try to use the scanner I get the error message cant communicate with scanner and computer. Can anyone help?
Same problem. No solution.
same problem!
my printer won't scan. it say no enough space on disk...what was that supposed to be??what should i do??
I have the same problem. Canon says to uninstall, reinstall, blah blah. It never helps, and they just keep you going in circles with the stupid tech support "scripts" that they read through.
Is there any REAL fix?
quero baixar um programa para usar minha empressora pois formatei meu pc era windows vista agora é windows xp como faço
I bought an HP Pavilion tx 1000 tablet notebook with pre-installed Vista. I installed the driver for Canon PIXMA MP160 but scanning does not work. There is no problem with printing, though. I have already tried to re-install but it does not work, either.
its fuked up
Solution link . . . http://www.CanonPIXMAMP160InkJetPrinter....'
