Question about Recoton Advent Advent DVD-8200 DVD Player
Fast forwarding movies and listening to movies without headphones
We recently purchased a 2005 Trailblazer with an Advent DVD player installed after market by the previous owner.  We do not have an owner's manual or a remote control, so I have a few questions. Is it possible to listen to movies without headphones? Also, when the engine is shut off while watching a movie and then started again, the movie starts all of the way back at the beginning.  We have not found a way to fast forward to the place we left off.  Is it possible to do so? If you can answer either or both of these questions, my family will be grateful. Thank you! wkeith116@yahoo.com
  • Recoton Advent Master
  • 10,291 Answers
Https://www.manualslib.com/manual/2384/Advent-Video-Mobile-Adv38.html#manual There is no speaker in this unit, so it's headphones only. The unit is not wired to an always hot fuse. Find a fuse that is always hot even when cranking the engine and the player won't start the movie over.
Posted on Apr 16, 2017
3 Suggested Answers
  • 276 Answers
SOURCE: Advent dvd 8200 plays for about ten seconds then
check the user manual can be misconfigured or also reviews the mechanism of the lens
Posted on Sep 09, 2009
  • 11800 Answers
SOURCE: I bought a 2007 GMC
These types of dvd's are custom installs so the brand and model pf the player would have helped.
On them the sound is sent in 3 ways:
1 - usually there is a cable coming from its audio output connections to the AUX input of the radio. You will have to check the player to see if one was installed; if it has you must make sure the radio is set to use the AUX entry as a source and that the cable connecting them is intact. For testing purposes you should connect a separate amplifier to the player thru these output connectors to see if you get a sound; if you don't then the defect is in the player. Check the audio settings, if they are ok then the defect is hardware and the player will have to be taken to a repair shop.
2 - if the guy that installed it didn't wanted to bother with the hassle of removing the head liner to draw the audio wore then it has most likely just set the connection thru the FM modulator: the player has a modulator that transmits the sound thru the FM radio band; to listen to it all you need to do is to tune it at the frequency of the modulator - usually between 88 and 89.5 MHz.
3 - the headphones - very simple devices. The only thing you can check here are the settings from the player.
Posted on Dec 23, 2010
The head phone jacks for the DVD player work. Can you use wireless headphones to listen to the movie
Yes. The headphones need to have an available connection from the DVD to the wireless headphone transmitter.
Hope this helps?
Mar 18, 2017 | The Audio Players & Recorders
I have kia sedona 2005 and have a question the dvd(movie) the sound not listen outside only with headphone its posssible to do somehing to listen without headphonesand how ?
there is a connection that can be connected to your radio input if you have one, if not you can use the same phono output from the dvd player (its marked) and get a unit that fits in between your antenna lead and the radio that allows you to tune to a frequency and hear your dvd sound through your radio speaker system. (available from ebay)
Mar 03, 2017 | 2005 Kia Sedona
I just recently bought a 2003 Chev Trailblazer with a DVD player and I wanted to know if the sound plays over the stero in the vehicle. Also does it use wireless headphones and where can I get them.
Sure it will play only has to be hooked up properly. Wireless headphones can be bought from'
http://www.infraredheadsets.net/chevrolet/2003-chevrolet-trailblazer-ext-replacement-dvd-player-headsets/
Dec 07, 2010 | 2003 Chevrolet Trailblazer Ext
Trouble w ir headphones
check the batteries in the headphones
Jan 22, 2010 | Audiovox Car Audio & Video
2005 Escalade DVD no sound through headphones
wireless sensor on unit is one of you prob its not picking up signal or head unit has fault
Jul 01, 2009 | Panasonic CY-VHD9500U Car DVD Player
Honda Odyssey DVD player sound without the headphones
You can set the sound to play through the car's speakers. If you don't want it too loud in front, you can use the audio setting for the fader to just play in the rear.
Jan 15, 2009 | 2004 Honda Odyssey
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
How do you work the sound on the DVD player?
I have a 2005 with DVD - but do not have the wireless headphones. I use the AUX button on the front radio to switch between FM/AM/and the DVD Player. I do have headphones jacks in the roof console by the DVD player, but have never used them.
Aug 06, 2008 | 2006 Chevrolet Uplander
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
Wireless headphones
If you're handy, you could rig up a wireless solution to this. The problem is that you have two screens, each presumably playing a different movie. If you purchased an off-the-shelf wireless transmitter accessory, you could connect it to one of the screens. But then if you purchased a second wireless transmitter accessory, and connected it to another screen, you would need to make sure both wireless transmitters were operating on different frequencies, so that each person could wear a different pair of headphones and listen to their own movie. Hopefully this makes sense. You could use either an FM Modulator to do this, or an Infrared Audio (IR) transmitter... Remember, these units aren't like factory installed headrest systems; they don't have the wireless audio transmitter already built-in, so you can't just buy wireless headphones and listen to them.
Aug 17, 2007 | Venturer PVS62911 Car Video Player
Recoton Advent Advent DVD-8200 DVD Player Logo
73 people viewed this question
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
