Question about EliteGroup 915G-M Motherboard
I disabled the lan and when i enabled it again it won't work
The onboard lan was abit slow so i decided to disable it and install a PCI lan instead, but after installing the PCI Lan card it didn't seem to have any better performance. So i decided to reactivate the onboard lan , but unfortunately I don't think that it is functioning well because even if I manually assign an IP adress at the end it owuld still say that it has no IP adress. (run command/ cmd / ipconfig / all) it would show there that there is no IP address assigned to it. Please help...
    President:
  • 2,351 Answers
Hi, well now you have windows registry confused. The PCI card may have come with software & you installed it. (See if its listed in add/remove programs & uninstall it), than go to this link & download the free software to clean your registry. (Keep the onboard lan disabled in the bios).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
When the program finishes close the program & shut down the system. Than boot the system & enter the bios. Enable the onboard lan. Save & exit. With any luck windows will see your lan & ask for the software. You can use the CD to guide windows to the lad driver software or you can download it from ECS. The online lan may be a bit newer or may not be. Click here to go to ECS web site:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=474&DetailName=New&DetailDesc=915G-M%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
If you are running XP install through windows device manager.
Run into trouble, just let me know what the trouble is & we'll go from there.
Mike
Posted on Oct 01, 2008
How to disable on-board VGA card my machine Gateway E-4620d I have installed a External NIVIDIA Graphics Card into my machine Gateway E-4620d how disable on-board VGA
In the bios there should be a tab for onboard devices. Just scroll through the tabs until you find one called VGA. Cycle through the options and pick disable if the option is enable/disable only selections....or pick auto if the choices are either onboard or pci-x , pci, etc.....
Jul 25, 2012 | Gateway E-4620d Desktop Cpu Dual Core...
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
Jan 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
I've lost the onboard video for my Intel D915GAG. I've installed a PCI video but still nothing. How can I disable the onboard video so it recongnizes the new video card?
Hi
You can disable the built-in video card in BIOS
The BIOS is accessed by pressing the F2 key
Then     Advanced > Video Configuration Menu
And set Primary Display Adapter>PCI
            Primary Video Adapter>Ext PCI
And Exit Saving Changes
Aug 18, 2010 | Intel D915GAG Socket 775 Motherboard -...
No lan connection
You can enable it again, just goto control panel, open network connection, there will be local area connection icon, Right click on it and click on enable.....
If there is problem again use motherboard cd and install lan card drive again...
Feb 11, 2010 | Intel D915GAG Socket 775 Motherboard -...
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
System unable to boot and showing signs of motherboard audio device conflicts(device type realtek)
hi iasmeer,
-to just boot up without any sound device,
remove any soundcards from the PCI- slots, disable the onboard sound device in the BIOS!
It looks like you are facing IRQ conflicts, your computer cannot handle all the hardware devices installed.
to solve this,
in BIOS set IRQ management so that the BIOS handles the PCI devices(set everything to auto),
disable the plug'n'play-operation system option to prevent windows from doing the same thing again( it'll then just take the IRQ information provided by the BIOS)
now enable the onboard sound device and make sure you have all
the drivers for the onboard devices(sound, LAN-card etc.) fitting your operation system on CD or thumb-drive, boot up and install the drivers.
Restart and by chance everthing isO.K. by now.
if not, please come back with more information on the sound device(onboard or not) and the winversion, so we perhaps can find you the appropriate driver(if you don't have it on the CD you purchased together with the mainboard..?)
Good luck
Sep 07, 2009 | ASUS P5GC-MX FSB1066 Motherboard
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
Falta instalar " la controladora simple de comunicaciones PCI"
Fijate en esta página que tenes los drivers de las PCCHIPS viejitas. Tenés además, que controlar que el jumper JP3 que habilita la placa de red.
Jumper JP3: Enable/Disable Onboard LAN Use this 3-pin jumper to enable or disable the onboard network adapter.
Function
Jumper Setting
Enable Onboard LAN
Short Pins 1-2
Disable Onboard LAN
Short Pins 2-3
SUERTE!!!!
Dec 23, 2008 | Pc Ware M748LMRT Motherboard
PCI-express won't come up.
BIOS Setup Utility; go to Advance Chipset Features
PEG Port is your PCI-EXPRESS…Enable/Disable
Nov 10, 2007 | EliteGroup 915G-M Motherboard
EliteGroup 915G-M Motherboard Logo
112 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
