Computer wont power up after graphics card inserted
Im using a lenovo thinkcentre s51 type 8171. trying to install a geforce 8500 gt. when i insert the card the comp. wont fully power up. it has power even the fan on the card is running but i get no monitor ,keyboard or mouse. all i do get is a series of beep sequences then nothing.
  • 2 more comments
  • deltasergean Sep 29, 2008
    its a 4-2-3-3 beep code
    problem with this is there is no selection in this comps bios to turn off the onboard. i have looked doesnt seem to be anyway only selection is pci wich im not sure if that means it will try to start with pci slot or what but i have tried that aswell same results. i looked at user manual there is two possible aswers to the beep code 1 is screen retrace failed or the other all it says is that it is a fru/ and motherboard is the answer. for screen retrace failed i have no clue im fairly illiterate when it comes to computers the second would suggest i replace the mobo and that seems incorrect because everything operates correctly.
    hmm thought i posted this but it must not have posted it turns out this comp was supposed to be shipped with a plastic bevel over the pci e express slot (though it did not) that prevents you from inserting anything except a pcie x1 ,then even the vendors website gave inncorrect spec on the machine. so needless to say time and money wasted due to inadequate informatioin from this comps vendor and i have to say the worst ever support i have talked too aswell
  • John Hong
    John Hong May 11, 2010
    Please describe the beep sequence
  • Computers & ... Master
  • 787 Answers
Remove the video card.
Boot the system and go into the BIOS
Set the onboard video to either auto or off, or in some cases you can change priority
Turn off the computer, reinstall the video card and give it a try.
Posted on Sep 29, 2008
  • John Hong
    John Hong Sep 29, 2008
    I agree, it is much more likely that this particular video card is not compatible with your motherboard. By any chance is the onboard video ATI?
    a thought, silly question but I have to ask - does this card require additional power and if so, do you have power going to it?
How to install hdmi out on thinkcentre s51 8171
no need to install. plug the hdmi cable in the pc. other point in the tv or projector. select hdmi2 in tv or projector.
Oct 15, 2012 | IBM ThinkCentre S51 Intel Desktop PC -...
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
I have a lenovo thinkcentre S51 8171 KUU. It was working fine until about a month ago, when it suddenly stopped working. The computer will power on, the fan will turn on, but the monitor will not display...
IF YOU JUST USE THE ONBOARD GRAPHIC,I THINK SOMETHINK IS WRONG WITH IT.
IF YOU DONT USE THE ONBOARD GRAPH.
CHANGE GRAPHIC CARD, THE S8171 SUPPORTS ATI x700 AND 700 pro, THEY HAVE 128 ,256 or 512 MB. THIS GRAPH._CARD IS A PCIEx16 and it will work WITH YOUR NORMAL POWERSUPPLY. NO EXTRA POWERCABLE FOR PCIEx16 NEEDED. AFTER INSTALLING, BOOT THE COMPUTER, GO F1 OR F2 TO THE BIOS. SET VIDEO SETUP TO PEG an STORE IT. NO OTHER CHANGES IN BIOS, NEVER GO TO IGD (THIS IS ONLY FOR ONBOARD GRAPH. )
NEVER GO TO COMBO.
OR MUCH MORE SIMPLE, USE AN OTHER MONITOR FIRST.
Aug 21, 2011 | Lenovo ThinkCentre S51 8171 PC Desktop
Free download Installation geforce 8500 512 bm
Download the driver here at nvidia:
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
Select:
1.Geforce
2.Geforce 8 series
3.Geforce 8500 GT
4. Your operating system 32 or 64 bit
5.Language
6.Press seach and download and install.
Hope this will help you.
Mar 22, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
What graphics card should be used to upgrade a IBM S51 8171 ThinkCentre? This unit only supports PCIe cards. The GeForce 8400GS will not fit
after the 8171, there are 3 letters or numbers (type) .. depending on the type, select it from the second link and take it from there to get (onboard) graphics-card drivers
hello
see links below to get drivers and get better understanding on the parts in your computer
select the correct OS when you obtain drivers
the third link gives you all drivers for S51 , 8171 series
http://www-307.ibm.com/pc/support/site.wss/MIGR-58581.html
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=11&familyind=179854&machineind=179923&operatingsystemind=49980&template=%2Fproductselection%2Flandingpages%2FpartsInformationLandingPage.vm&validate=true
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55830
hope this helps you
Oct 31, 2010 | IBM Lenovo GeForce 6200 Graphics Adapter...
Computer would not come on when you press the power button and nothing works.
Bad Power On switch, or bad Power Supply.
(Weak voltage power rail)
The Power On switch is located inside the plastic Power On button.
This is an example of a generic ATX power on switch,
http://www.directron.com/atxswitch.html
One that I have found fits many desktop computers.
There is a test to see if the problem is the Power On switch, or the Power Supply.
The test requires using a jumper wire on the ATX main power cable's connector.
Jump the Soft Power On wire (PS_ON) to ANY ground wire.
This is Lenovo Support, ThinkCentre S51 desktop computer, User Manuals, and the link to download the HMM.
Hardware Maintenance Manual.
Left-click on the top blue file listed.
Starts with - Hardware Maintenance Manual (HMM) (March 2009) Thinkcenter A51........and ends with S51 (type 8098, 8171, 8172, 8173)
Date to the right is 2009-08-05
On the next page look under the heading - File link, and click on -
19r0486.pdf in blue.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Additional time may be required to fully download. Let the file download all the way before looking through it.
(Took 4 seconds to see the first page, and over 3 minutes to fully download just now. Medium speed DSL connection)
With this HMM you can follow along with illustrations, and details, as I detail how to perform the above test, on your IBM ThinkCentre.
(FRU = Field Replacement Unit)
S51 is the Product Model.
There are several Types.
Page 98 details how to open the ThinkCentre S51 desktop computer. ('Pizza-box' computer case)
(Types 8095, 8141, 8142, 8145, 8420, 8421)
Page 123 details how to open the ThinkCenter desktop Tower computer case.
(Types 8143, 8144, 8146, 8422, 8423, 8427)
Page 145 details how to open another 'Pizza-box' style computer case.
(Types 8098, 8171, 8172, 8173, 8424, 8425)
Computer unplugged from power, observe Anti-Static Precautions, BEFORE you reach inside.
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, TOUCH the metal frame of the open computer case. Touch an unpainted surface.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
With the flat desktop models, ('Pizza-box') you may have to release the lock, and tilt the Harddrive, and optical drive up. (CD/DVD drive)
This will allow viewing the motherboard.
With the desktop tower model you may have to ease a few cables over to view the motherboard.
You are looking for the 20, or 24-pin ATX main power cable.
(Don't know if your model uses a 20-pin, or a 24-pin.
This is what you're looking for,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll down to see the 24-pin ATX main power cable.
Look at the photo to the far right.
The Green wire is the Soft Power On wire.
ANY Black wire is a Ground wire.
With the ATX power cable plugged into the motherboard, as shown in the photo to the far right, you are going to insert a jumper wire down into the socket holes.
The jumper wire goes down in the socket hole, Right next to the wire that is in the hole.
It goes down in far enough to touch a metal terminal, that is at the end of the wire.
(Approximately 1/2 inch)
The jumper wire of choice is a paper clip straightened out, then bent into a U-shape.
The middle of the U is wrapped a few times with black plastic electrical tape.
(Trivia: One wrap of black plastic electrical tape is enough for 600 Volts DC)
The voltage you will be dealing with is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
You may wish to wear a glove on the hand that holds the jumper wire. There may be a small spark.
The Power Supply, (Computer), is plugged into power.
One end of the U-shaped jumper wire, is inserted down into the socket hole with a Green wire. (Right next to the wire)
The other end is inserted down into a socket hole with ANY Black wire.
The contact made is no more than 2 seconds. (1001, 1002)
If the computer comes on, (Power Supply actually), the Power On switch is bad.
If the computer does not come on (Power Supply), the Power Supply is bad.
It's an ATX power supply, probably a generic model made by Bestec, HiPro, Delta, or another low quality power supply manufacturer.
The Wattage is probably stated at Maximum 225 watts.
An ATX style Power Supply is used by over 80 percent of desktop computers out there. You can buy a decent one for around $30 US.
(Power Supply case size is approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall)
You can use a 300, or 400, or 500 Watt power supply.
Doesn't matter. Won't hurt the computer.
A computer ONLY uses the power it needs, and no more
Post questions in a Comment.
Regards,
joecoolvette
Oct 14, 2010 | IBM ThinkCentre S51 Intel Desktop PC -...
Will a EVGA GeForce 6200 work on an IBM think
The EVGA is nterfacePCI 2.1
The Lenovo 8171 has two PCI 2.2 slots
  • Slot 1: half length, 1 lane PCI Express (graphics)
  • Slot 2: full height, half length, 32-bit PCI 2.2 (5v)
I would say yes to this.
Nov 17, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Sapphire HD2400 PRO 512M - Doesn't seems to be working
For windows to work, it needs the card's drivers to display properly. The bios will display, and the beginning of windows load messages will show, but then it switches to the installed display driver. Take the card out, and use the old display method, and load the drivers for the new card. Then set the screen resolution to 800x600 and the shutdown, and install the new card. The bootup should go correctly, and once the new drivers are in, then set the resolution desired.
Oct 14, 2009 | Computers & Internet
GeForce 8500 GT installation problrm
Try looking for a message in the BIOS startup screen usually delete or an "F(X)" something button i.e. F1 or F2 That says it will let you chose your boot device. If you can than press that and chose the hard disk option. If it doesnt let you or it doesn't work than theres probably something wrong with your hard drive and I doubt it has much to do with your video card unless the driver caused it. In that case try starting your computer in safe mode by pressing F8 after the BIOS startup and selecting safe mode and then uninstalling the driver from the change/remove applications part of the control panel. Of course if none of that works you could just yell and swear at HP until they help you. :)
good luck
Jul 04, 2008 | PNY Computers & Internet
Nvidia GeForce 8500 GT
Have you removed the old drivers and reinstalled the new ones... i.e right click GeForce 6100, uninstall, then reload the drivers you got with the GF 8500
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
507 people viewed this question
David Payne
David Payne
