Speakercraft bb50 power amp
Need schematic for a speakercraft bb50 2 chan amp, or the part number for transistors q23 and q33 on the pc board. Called the company, but no help !! Should I bother fixing or just trash it ??
  • blackhorser Oct 01, 2008
    Dan, the transistor markings are faded, however, q33 has a y??4x on the case, and another marking c2235 and transistor q23 has a bl4h with a c2240 on its case. There is an 8 pin IC close by with a part no. 455800 JRC and 4135G on its case.Also close by is a electrolytic cap c8 ..value is 220 uf@ 25v.
    Thanks,
    Frank
  • 4,234 Answers
Can you post the markings on the existing transistors? Also, if these are the output transistors, there shouldbe a complimentary one located close by Q24+Q34 maybe? Post those markings too.
Thanks,
Dan
Posted on Oct 01, 2008
  • ABRsvcs Oct 01, 2008
    THe C2235 is actually a 2SC2235, the same for the other C2240 = 2SC2240. Both are common transistors and are inexpensive. The 8-pin IC is a standard opamp IC and can be any of the following:
    MC4558, NJM4558, KA4558 Any of these will works and be the same. Try changing the transistors and the opamp. All together you are talking about less than $5
    Dan
Is there a way to hookup the controllers for a mzc-66 to the bb50-s?
Yes, judging by the large picture of the back, clickable here...
https://www.referenceaudio.se/products/5661/speakercraft_mzc-66.aspx
and the decription...
http://www.soundseller.com/product_info.php/products_id/279
I'd say you can slave up to 12 audio channels off this thing. It neither knows nor cares what they terminate into.
Feb 23, 2011 | SpeakerCraft BB50-S 2-Channel Amplifier
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
Our SpeakerCraft BB835 won't power up. Could this be as simple as a blown fuse?
hello,
this could be a fuse, check for other fuses on the board.
Also check the power transistors using a multimeter..
May 23, 2010 | SpeakerCraft BB835 8-Channel Amplifier
Schematic Diagram
I don't have a schematic but I have photos of that amp. What part do you need to identify?
babin_perry@yahoo.com
Jul 21, 2009 | Kicker KX1200.1 Car Audio Amplifier
Transistor source and price
rockford fosgate use hexfets.they are made by international rectifier and are available from toronto. they are n and p channel devices.they are not bipolar transistors...
Jun 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
**** speakercraft!
Can you post the markings on the transistors themselves? I will look up what I can and try to get you a more common substitute. Post what eve information you can about the transistors and I'll see what I can find. The model and the output specs that are published for the unit would help too. Thanks, Dan
Jun 06, 2009 | SpeakerCraft BassX-10 Subwoofer
ZX-8100
I'm not familiar with that particular amp but generally, the only transistors that burn are the ones in the power supply. If the adjacent transistors had numbers like IRFZ44, IRF3205 or similar, the burned transistor is likely the same as the ones next to it.
Confirm that the center and right-most leg of the burned transistor and the transistor next to it are directly connected by large traces on the circuit board. Also confirm that the center leg goes to the large windings of the power transformer. If it passes these tests, the transistor is one of the power supply FETs. The numbers on the adjacent (parallel connected) parts will be the same as the burned one.
Jul 16, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
258 people viewed this question
 Grubhead
Grubhead
