Question about Panasonic KX-TGA650B 5.8GHz 2 Line Expandable Handset for the KX-TG6500 Series 037988474806 Phone
KX-FG6550 Phone/FAX Base Unit Compatibility With Other Phones
I have a Panasonic KX-FG6550 Phone/FAX Base Unit. The wireless remote phones listed as compatible with the base unit is the Panasonic KX-TGA650B. Panasonic makes other models 5.8 Ghz spread spectrum two line remote extension phones. Are any other of these phones (like the KX-TGA560) compatible with the KX-FG6550 Phone/FAX Base unit? The problem I have is finding the KX-TGA650B phones for less than three times the MSRP prices.
Bob Shon
Rshon2000@gmail.com
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
mrfixit64857
  • 9 Answers
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Posted on Jan 01, 2009
SOURCE: Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Posted on Apr 02, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
chiefmecha
  • 600 Answers
SOURCE: Phone Screen(s) say "NO LINK
To resolve this issue, you have to re-register the handset.
+++++this was excerpted from original troubleshooting guide from Panasonic
Posted on Aug 18, 2010
How do I add a cordless phone to my two line KX-T7731 Panasonic phone?
Hello Shantell...
I could be wrong (am... quite often)
I have not seen (nor found) the SPEC that defines
the KX-T7731 as a "wireless" BASE-STATION.
((looks more like those stations can be associated
together to form a private exchange (business office or delux home intercom system)...
Could be wrong...
IF SO...
It depends entirely if you are buying "NEW" or
re-applying a PREVIOUSLY "programmed"
wireless REMOTE units.
Definitly call 1-800-332-5368 to
verify 2 - line cordless availability/compatibility
My VERY BEST advice is to go ManualsLib
and get the OWNERS INSTRUCTIONS...
Determine the compatible remote...
Buy that & follow the (usually very simple) instructions...
Hope I am helping
Carnac the Magnificent
Oct 17, 2017 | Panasonic Lands Phones
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
Instruction manual for KX-TGA931T cordless 4 phone set
To get the operating instructions for your phone, you need to also know the model number of the base, not just the handset. Look under the base for the number, then go to this site...
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TGA931T?Ns=&NttRaw=KX-TGA931T&Nr=12001&Ntt=KX-TGA931T&No=0&URL=vSupportSearch&N=779832097&Ntk=SupportSearch&Ne=&y=24&x=17&cmTag=true&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&jspStoreDir=panasonicdirect&catalogId=11017&edb=com.panasonic.commerce.search.beans.PNAEndecaDataBean%405ea56c09&storeId=15001
Once you are there, go to the tab "knowledge base" and type in "manual". Selecting the option to look up operating instructions will allow you to select the phone base that is compatible with your phone.
Or go here and see if any of these phones are the same/within the same series of phones as yours...
http://service.us.panasonic.com/operman/findmanual.aspx?model=KXTGA93
Feb 04, 2011 | Panasonic Lands Phones
One of the handsets to my Panasonic KX-FG6550 5.8Ghz base seems to lose connection with the base station - it hangs up the call. The battery is full but it acts like the battery was empty, i.e., shuts...
Your battery needs to be replaced. The software inside the phone indicates the battery charge level by the voltage of the battery. Your battery really can't hold a charge anymore, which is why the phone shuts off.
Replace your battery - that will fix your problem!
Jun 10, 2010 | Panasonic KX-TG5230M FHSS GigaRange...
Ringer
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG2740S
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Apr 21, 2010 | Panasonic KX TGA270S Cordless Expansion...
A drive for panasonic KX-FLM551/FLB751 ?
I checked their website http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/model.KX-FLM551
It doesn't list any Vista drivers yet. Have you tried running it in Compatibility mode for XP?
Jan 14, 2009 | Panasonic Workio DP-2330 Printer
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Remote access
I have a very similar Panasonic phone, but I don't use the remote feature. In the past I had a similiar phone where I just dialed the phone number and entered a three digit code that I assigned and was able to listen to the messages. Here is a link to the owner's manual. Look on page 29-30.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG1033S
Oct 02, 2008 | Panasonic KX-TG1033S Cordless Phone
Lands Phones Logo
98 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
