Question about Fuji FinePix S7000 Digital Camera
LCD screen I have scratched the LCD screen on my s7000 but is it the lcd screen or a plastic cover over the actual LCD ? if so can the plastic cover be replaced ?
    President:
  • 423 Answers
It's a plastic overlay cover which can be replaced. It's held in place by double sided tape. Fuji can do it for you, or you can see if someone can order the part for you. Fuji Canada has a policy to not sell parts to consumers to install, because there's been lots of problems with people trying to install the part and damaging the camera even further. Now the consumer blames Fuji for a bad part, and for the subsequent damage to their camera. Better to let Fuji (or a qualified shop) handle it for you.
Posted on Oct 07, 2008
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Damaged plastic screen cover of my flat panel LCD. Anybody have any fixes? T.V. works great but blemishes on plastic can be seen. I'm wondering if a new screen cover can even be bought. Sceptre X37sv-Naga...
most lcd/led tv,s the front panel is the display you can try polishing the screen with very fine abrasive like jewelers rouge or your local car dealer sell plastic polish to remove scratches from plastic headlamp lenses if not its a new display a new tv is poss a better option. i have used silver polish to rejuvinate car headlamp lenses to good effect
Dec 13, 2017 | Sceptre X37sv-Naga 37 in. LCD Television
LOOKS LIKE SCATCHES BUT THE SCREEN ISN'T SCRATCHED AND BLOOBS OF LIQUID ON THE INNER SCREEN. A LINE DOWN THE CENTER OF THE SCREEN TOO
That really sounds like the LCD screen is cracked. The front will not feel cracked because of a clear plastic cover sheet but behind it is the LCD panel. The liquid you see is part of the screen leaking. The LCD actually means "liquid crystal display" and that is what you are seeing leak out between the cracks in the panel. You will need to have the panel replaced to clear the problem. You can get the panels from Ebay if you want to do the repair yourself. This type of repair is not covered under the Acer warranty. If you have any questions just use the email address below.
Buddy
Corporate Computer
www.ccl-la.com
h@ccl-la.com
Dec 16, 2009 | Acer Aspire One PC Notebook
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Badly scratched bottonm screen-
The bottom screen of the DS Lite is made up of 3 parts. The LCD Screen which provides the pixel images you see. The Touch Screen which basically is a piece of plastic that sits on top of the LCD portion picking up the touches from your stylus. And a protective shield layer, to protect from scratches. They are all glued together so unless you are looking, you would just think they were one screen.
If its just scratched up, you really only would need to replace the protective cover, because the Touch Screen and LCD Screen should be unscathed beneath it. However, if for some reason, you don't have that protective cover, or you just want to replace the screen anyway, you have options. You can buy the Touch Screen alone (attaching it onto the already owned LCD screen), or with a new LCD screen attached. As far as the protective layer, I haven't done enough research to know if you can buy them or not, but they do sell plenty of different kinds of screen covers that you can just stick on, which I am sure would be a fine substitute. My price estimate for the Touch and LCD Screens together would be anywhere from $5 to $20.
If you decide to replace the entire screen, I urge you to know exactly what you are getting into. Follow guides, know the parts, and have the tools you need. When opening up a device like this a lot can go wrong that you were not counting on, so take care.
When I fixed my own DS Lite, I found that it was very helpful to watch demonstration videos ahead of time, so I knew the steps, and when actually working on it, making sure I had guide available.
Here are some videos and guides you can look at to make sure you know what the project entails, as well as how to go about it:
http://www.youtube.com/watch?v=fJ3W6Y9zTQY
http://www.pwn3d.us/archives/440/
http://site.powergamingparts.com/RepairNdsl.html
http://www.flickr.com/photos/retroleum/sets/72157605949769269/ <-- This is more for just extra reference pictures
There are probably better guides out there so do some research on your own as well.
I hope that helps.
Jun 17, 2009 | Nintendo DS Lite Console
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
Scratch on LCD screen of the monitor
Unfortunately, most lcd panels have a polarization filter in the front, this looks like a plastic coating that is actually in front of the glass of the lcd panel, if it's scratched, there is no real way to fix this problem other than replacement.
Jun 22, 2008 | LG Flatron L1710S 17" LCD Monitor
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Fuji FinePix S7000 Digital Camera Logo
71 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
