Belkin (F5D7050) 802.11a/ Wireless Adapter
Hi thanks for help, I should have mentioned its a usb adapter,ive tried uninstalling restarting reinstalling, useing different usb port,downloading software from belkin,on different computer,incase its a newer driver or something,useing system restore and then reinstalling .If you`ve any other ideas Id be gratefull as im a bit stuck now
Cheers Andrea
  • 4,338 Answers
I just noticed that it is a 802.11a/ . "a" wireless products do not work correctly and you need an "a" router to connect to. The "g" protocol is the most common and reliable.
If it is a new adapter, I would return it and get a 802.11 g adapter, not a USB.. they cost about $20.
Posted on Sep 28, 2008
Hi I'm using the belkin n300 wireless n usb adapter to connect to the router (dlink dir 655). the connection speed is good (130mbps) and I'm getting excellent signal (4-5 bars) but internet speed...
in my case i dont use belkin wireless usb.ive rather use same brand with my router.i got dlink router too just like yours..and i have edimax wireless 802.11b/g/n nano usb adapter..well up to now no problem getting slow DL and UL. try it..
Jul 06, 2011 | Belkin N300 Wireless USB Adapter
I keep losing the connection to my Linksys N router...why??
1.Primarily, if you use a N standard wireless router, you must go in for the same N standard adapter, to get full efficiency. You didn't mention the model no.
2.If you have any other wireless computer in your house, check with that if it also has the same issues. Try checking with new and old wireless devices.
3.If finally, you conclude that its only this Belkin adapter that is responsible for intermittent connection, then:
3a. Uninstall the Belkin adapter's utility and drivers from control panel(Add/Remove programs)
3b.Go to http://en-us-belkin.com/support and download the latest drivers for your model.
3c. Unplug the adapter and run the downloaded setup file. (Setup will walk you through from here)
But i could have helped you better if you had mentioned the model or part number along with the version of it.
Anyway, this would certainly work.
Jan 24, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Got a laptop that needs a usb adapter Ive lost the
Find the Version Number of the adapter
Then Click Here to get to the drivers
Download the Drivers for your Adapter
And let me know if it works
Jan 16, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin adapter will not connect to home network. It says poor signal strength even when I'm in the same room!
hi it is simple to connect to the wireless network using the belkin adapter.
You can switch over to the windows utility. that should work. it does not work then try to uninstall and reinstall the adapter.
Click here for more info
Oct 11, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin (F5D7050) 802.11a Wireless Adapter think ive installed this ok, device manager says working, but no flashing led on adapter on adapter software and says no network avalible however kids wireless...
Power off the computer, take out the adapter. move it to a different PCI slot, then restart.
If that does not work:
Uninstall the Belkin driver,
Power off unit . remove adapter.
Power on and install the drivers.
Power off once more and reinstall the card.
Restart and it should work.
Sep 28, 2008 | Belkin Computers & Internet
Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
May 18, 2008 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
BELKIN MISCONFIGURED?
Uninstall the old installation of the driver and the restart the pc. disconnect the belkin and install the software of the belkin.After installation insert the belkin device and let the system detect it. if this act thesame then maybe you update the driver of your belkin here you can download: http://www.belkin.com/support/
Jan 24, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin N1 Wireless USB Adapter
Hi Emma,
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Please let me know how you make out.
thanks
Jan 21, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
USB device not recognized
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
Jan 17, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
