Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Leaking at drum where drive shaft enters
My Amana Super Capacity Plus Washing machine is 10 or so years old. It has recently begun leaking where the drive shaft enters the drum, and the water is not spinning out completely during the spin cycle. Is it time for a new machine, or can I fix this myself? Any suggestions?
  • rickwoods Sep 29, 2008
    Thanks Doc. That's what I was afraid of. Any chance its a seal or a gasket that's blown? I think the spin cycle issue is related to the water on the belt due to the leak. I saw some smoke today when I opened it up. I think it's the alternator/ agitator. I'm guessing any fix would only be temporary. We're shopping for a new washer now. I'm hearing good things about front loading washers. What's your take?
Hi .well they are a lot more money and getting more complicated hard to repair thanks for th fix ya the appliance doc
Posted on Sep 29, 2008
  • 943 Answers
Hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Posted on Sep 28, 2008
My washer is leaking water
Frigidaire washing machine leaking water from bottom
www.washingpoll.xyz/frigidaire-washing-machine-leaking-water-from-b...
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Whirlpool Super Capacity Plus washer drum removal
What kind of residue? Grease? Sometimes a buildup of fabric softener will look like grease. If so, removing the agitator and inspecting it will show a buildup of fabric softener on underside. Rinse with hot water to remove. If you need to remove the inner drum, you will need a special tool for that. Try a local appliance parts business. They might loan or rent one, or sell you one. No filter to clean though. Grease should not be present as there is only the shaft of the transmission coming through a seal into the outer tub. Not likely to have grease migrate into tub. Fabric softener will be present on outer tub as well. Remove with hot water and plastic dish scrubber. Rinse and re-assemble washer.
Aug 01, 2009 | Whirlpool Washing Machines
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
I want to replace the water pump from my Inglis Washer
yes you can force it off it's bad anyway so go for it and when you do get it off clean the rust off the shaft before you put the new one on. You are doing great.
Apr 02, 2009 | Washing Machines
Amana top loading super capacity LWD35AW leaking
Hello horshomom
Welcome
You said, You just found out my machine is leaking underneath somewhere and you haven't taken it apart yet. Any suggestions or ideas?
How old is the machine?
How much water leaks and when?
It usually is a leak in or around the drain hose.
I've seen a clamp vibrate loose near the pump.
You should be able to find it!
Let me know. Huuum
Please remember to leave a rating.
Oct 04, 2008 | Amana Washing Machines
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
355 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
