Question about Freezers
Chest freezer runs almost non-stop.
Freezer runs at least 20 hrs. out of 24. Temp is -5 (F) and can't be set any warmer.Apatch of ice has formed on the outside at the back about 6 in. square. and 1/2 in. thick.
Freezer sits 3 in. from the wall,condenser coils are clean, door seal appears to be soft and pliable with no cracks. Unit has been defrosted.
  • 943 Answers
Hi. thanks for the said you could not set the thermostat any warmer. so no matter what you do. it is not changing a thing. -5 the block of ice on the back, is a sign of too cold & running to long. was it frosted up inside the freezer i would replace the cold control thanks the appliance doc
Posted on Sep 28, 2008
Fridge freezer stoping after 24 hrs
most of these freezers have an automatic defrost cycle.
after so many hours of chilling it will stop and run a de-icing cycle.
this is accomplished by one or two heating elements.
if one of the elements is burned out it will not run the defrost cycle.
and will ice up quickly.
depending on the model the heaters will usually cost about 15 to 20 dollars and they are easy to replace.
look up the model of your freezer and download the pdf files they will usually have a pictorial diagram showing the location
a defrost timer usually does nt fail on them unless it is physically damaged.
Aug 31, 2013 | Freezers
I want to know how i put the temperature control, and what means the control with this simbols: - O
The switch that looks like - o is an on and off switch, and set the temp in the middle of the scale, and let it sit for 24 hrs. check the temp and adjust as needed. Hope this helps
Sep 17, 2009 | Haier 4.5 cu. ft. / 127 liter Chest...
My fridge freezer is running non stop
It is probably because it's not getting cold enough to cut off. If you slowly turn the thermostat to warmer it should cut off when it gets to that temp.If it doesn't cut off then it is a thermostat problem. When you have heavy ice buildup on the evaporator coils inside the freezer behind the back panel that will hamper the cooling. This is caused by a defrost system failure.
Aug 15, 2009 | Freezers
Bought new freezer, came yesterday. It hasn't stopped running. What do i do ?
Hi, Give the freezer 24 hrs to get temp set. Make sure the control dial is set half way.
Please let me know if I can assist you further.
Jul 02, 2009 | Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Nov 20, 2008 | Haier Freezers
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
189 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
