Media Jam Registration Konica Minolta 3300
A week ago I was printing labels and had a jam. Not all came out but with a pass of paper through it brought all but one. I was able to print with a wrinkle periodically until now. The printer says "Media Jam Registration". There is nothing there. I have taken it all apart and see nothing and it still continues to show that. I have powered down completely but to no avail. Can you help me?
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
  • 170 Answers
SOURCE: paper jam
moz-screenshot-7.jpgClearing Media misfeeds
To avoid damage, always remove misfed media gently, without tearing it. Any pieces of media left in the printer, whether large or small, can obstruct the media path and cause further misfeeds. Do not reload media that has misfed.
The image is not fixed on the media before the fusing process. If you touch the printed surface, the toner may stick to your hands, so be careful not to touch the print face when removing the misfed media. Make sure not to spill any toner inside the printer.
Clearing Procedures
1. Pull the lever, and then open the top cover. If there is paper in the output tray, remove it, and then fold up the output tray before opening the top cover. Do not touch the transfer belt.
2. Slowly pull out the drum cartridge. removed drum cartridge on top of the printer keep it close and insure it is safe and stable where it sits. Be sure to keep the drum cartridge horizontal and place it where it will not become dirty.
Do not leave the drum cartridge removed for more than 15 minutes, and do not place the removed drum cartridge in a location where it would be exposed to direct light (such as sunlight).
3. Remove any misfed media.
4. Reinstall the drum cartridge
5. Carefully close the top cover
I hope this helps you and thanks for your question.
I the problem persists let Fixya know and we can detail a few items to check in order to determine the cause of the frequent misfeeds.....thanks........Whytfang
Posted on Mar 25, 2009
SOURCE: Imaging Unit Missing on Konica Minolta Magicolor
I had the same problem previously. I had a small piece of paper jam in the imaging unit
pulled it out and got the Imaging Unit Missing error. I could not solve the problem so I called it in under the extended warranty. Even the printer tech could not solve this issue. But, I look at this file, took off a the side cover moved the gear an viola! fixed..
Try page 3-308 of this PDF.
Posted on Apr 17, 2009
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ... > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Paper jam
when coping or printing? make sure paper is in the tray the way you set it up in the tray settings on the control panel and the driver. paper size, orientation, and media type all make a difference. clean the roller and make sure the lift plate moves freely.
Jan 12, 2013 | Konica Minolta Bizhub c203 Copier
Well a media jam is a paper jam remove the paper. Remove the transfer belt or the fuser what ever is required. chk web site for owners manual. Self Help Product Support Konica Minolta Business Solutions Inc
Aug 25, 2011 | Minolta 2430DL Color Laser Printer
My printer reads," Media Jam Registration" It of course will not print. I think I have cleaned all the jammed paper out of it but still will not work.
The paper registration senor accurator that tell the printer that paper has arrived and left the registration part of the paper flow may be broken (Sensor may be filled with paper dust) the accurator may be jammed.
Aug 09, 2010 | Minolta magicolor 3100 Laser Printer
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Imaging Unit Missing on Konica Minolta Magicolor 3300 after paper jam?
Apr 02, 2009 | Minolta magicolor 3300 Laser Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
179 people viewed this question
