Question about Canon MX300 Office All-In-One Printer
All of a sudden my printer just started printing in blue
I refilled my ink cartridges and they were working fine for about a month but all of a sudden my printer only wants to print in blue. i performed a nozzle check and it prints perfect. I print using photo shop and word 2007 and it does the same for both. I checked the printer settings and they were fine I even set it up to print only with the black cartridge but I get a message stating that it will only use the color cartridge or else just to cancel the printing and try again. please let me know what i can do to fix this because its driving me crazy.
  • 849 Answers
One color of your cartridge were finished, replace/refill the cartridge again
Posted on Oct 31, 2008
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
I need to reset my ink levels on my lexmark s305 after refilling cartridges
I managed to successfully refill the black cartridge for the S305; I did it when the printer warned of 'very low black ink' (although it didn't print very well - i.e. grey - until the following day). It kept displaying 'low ink' but printed fine for a few months.
I think if you can catch it before the printer decides it needs an 'official' refill or replacement then it works (although when exactly this is is a mystery, as it always displays 'low' for black ink).
Yesterday, the printer decided it wouldn't print until the cartridge was changed.
Refilled; waited for half a day;replaced several times; turned the printer on and off 5 times with no cartridge in (to see if it would wipe the printer's memory of the cartridge); and spent about 4 hours online trying to find a solution.
If it starts working tomorrow, I'll let you know. I don't want to mess about with software that may reset the ink levels. (If anyone finds some that works, please post!)
It looks like Lexmark have ensured they can pile in the cash with their original cartridges.
I've heard about generic cartridges that are chipped to avoid the above problem - I'll visit my local refill store soon.
There must be a way round this!
Cheers, Fronter
Mar 08, 2010 | Lexmark X3550 All-In-One Printer
No black ink printing
Try reinstalling the printer, as it sounds like a driver problem. This shouldn't happen, but occasionally the drivers get corrupted. And refilled cartridges certainly don't help, and may continue to give trouble even when replaced with OEM ones. Have you tried turning the printer completely off - disconnecting the power lead, for a few minutes? That sometimes clears things.
Jun 27, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Hp photosmart all in one C5280 -recommend keep cartridges topped up before they get past half way
for a succes refilling you can find averything you need in this kit
http://inkfilling.net/start-pack-a-hp.html
 each time you refill a cartridge you mast remove all air bubbles and old ink from cartridges
in this pack you can find refill clip to remove it
Oct 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
Troubleshooting Dell 924 all in one printer(Printer reads unsupported cartridge)
Try replacing the cartridge with a new Dell ink cartridge, the refill may have gone bad.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Pixma iP1700 error message
see if reinstalling the printers drivers and print software, see if that helps it,
regards
Paul.
Feb 05, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Cartridge problem
in most of the cases the refill will work for a few times then will not work one reason is because the ink gets dry inside the cartridge and second the contacts does not work when you uses that several times and the third the ink is not compatible with the printer no matter if that say for that kind of printer so if you wants to get that right get the new cartridge and end of the problem
Nov 03, 2007 | Lexmark Z600 InkJet Printer
Canon MX300 Office All-In-One Printer Logo
73 people viewed this question
old marine
old marine
