Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox WS55859 I have had this tv for years with no problem. Today the power went off for a couple of hours (not unusual) and when it came back on, I can't get the set to turn on. There is a green light that is labled "timer" and it is blinking but there are no other "signs of life!" Can't find the manuals anyway, either. How do I get the set to turn on? Thanks
  • Philips Master
  • 5,138 Answers
SET will not turn back on untill you have it fixed,check out hori output ,shorted diode, or STKs need replacing.
Posted on Sep 28, 2008
Scepter 32". Received this for Christmas 2012. It's worked beautifully up until about a month ago. When you turn it on the blue light comes on but nothing happens. You can't turn it back off without...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
It's not unusual for this type of electronics to only last a couple of years.
May 03, 2014 | Televison & Video
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
The set is almost 10 years old and has always worked perfect until today. . .
It soulds as of your solder joints are getting old and starting to crack. If the screen goes completely black then I would resolder all the major solder joints on the main PC board, and if you mean that the screen goes to all snow (as if the cable went out) then I would also pull the tuner and resolder the joints inside it too. If you do not have experience soldering on small PC boards then allow a qualified tech to handle it for you. The fact that it works sometimes means that all major components are fine and the repair shouldnt cost too much.
Jul 13, 2007 | Toshiba CF27H50 TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
