Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Won't spray my hoover steamvac silver won't spary the cleaning solution what can I do
  • 438 Answers
This could be caused by several things. First take the clean water tank off of the machine, and turn it upside down to inspect the bottom of the tank. There should be a gasket with a spring and valve stem, which you should be able to move the valve stem up into the tank when pushed upwards. If you notice that there is no gasket, or vale stem, you'll need to purchase a new clean solution tank.
If the valve stem and gasket are ok, then it is most likely going to the pump assembly that has gone bad. This is a little more difficult repair, you should probably look up your closest Hoover repair center, or independent vacuum repair store, and take it in to them to have it repaired.
Chris Jones
GoVacuum.com
Posted on Sep 29, 2008
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Owner's manual for hoover silver steamvac 5858-910
go to www.hoover.com and go to customer service support and download your mode for free or go www. retrevo.com
God bless you
Jul 14, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The spin brush wont spin but the water is spraying out and sucking up
possibly the brushes need cleaning http://www.hoover.com/pdfs/manuals/F5914900.pdf manual for your steamvac
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
My steam vac won"t **** up the water
Check the hose and make sure it is clear of debre and there are no kinks in the hose.
Aug 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
202 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
