Question about Electrolux Guardian Bagged Canister Vacuum
No power turned vacuum on and it shut down immediately
    Problem Solver:
  • 13 Answers
It could b many things. Take it to a Electrolux dealer. I can give u the closest one to u if u wish. Or I can have UPS pick it up from u. Do not take it to another vac shop as then u will void any warrnty u may still have. Im Elux Dealer 1-866-966-9350
Posted on Oct 02, 2008
Neato vacum powers up but immediately shuts down and flashes the "debris caught in brushes". I have taken the brush out and cleaned it but it still does the same thing.
Hi thanks for giving me the opportunity to assist yu. I know these little ones can sometimes be a real pain. I wonder at times if the "Coolness" factor is really worth it...Then I see it just doing its thing without me being there and Im like "Heck Yeah its worth it!" I know on my Zoomba unit under the brush you should find several differnt sensors. They kind of look like masking tape! Make sure they are clean. If not they will cause your unit to continuously shut down because it thinks it full!. Give it a try. Thanks.
Oct 16, 2013 | Neato XV11 Vacuum
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
When I turn on the unit and push on the level that draws the "arm" back, it immediately shuts off. I return it to the upright position and turn it on again and repeat the process. Same thing...
seems like there is a short in the unit. it is extremely hard to find kenmore parts. i would probably just go out and buy a new vacuum. Kenmores arent worth fixing.
Mar 22, 2011 | Kenmore Progressive Upright Vacuum with...
Vacuum turns on for 2 sec and then shuts down, full bag light on , but bag is new
This is more than likely due to a broken control valve assembly. I'm seeing quite a few machines come in for replacement of this part.
To be sure, disconnect the hose and turn on the machine. If it still shuts off immediately, or if you place your hand over the opening and it shuts off, it's due to a bad cva. If it continues running, then the problem is more likely due to a clog in the hose or the tube in the power nozzle.
Also, try replacing or removing the afterfilter and see if that makes a difference.
Sep 18, 2010 | Electrolux Epic 6500 Vacuum
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
Bag light stays on, powers on then shuts off immediately. What is the problem?
first check to make sure there is a bag in the machine, if so make sure that its in securely, there is a pin switch in the bag door that wont allow the machine to turn on if there is no bag in it. If that's okay, then find the knob on the top of the machine ( in the middle of the canister ) and make sure its turned to the maximum, that is a sensitivity knob that can keep the machine from working ( in case it was clogged, but if its too sensitive it could think the machine is clogged when it really isn't ).
Sep 16, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Turned off but won't turn back on
There is a safety switch where the front head connects to the machine, sometimes, readjusting the head will be enough.
Dec 19, 2007 | Kirby G5 Bagged Upright Vacuum
Aerus lux 5500
Hi.
Check & replace any filters that are fitted to machine.
Replace bag with new,
Clear hose of any foriegn items & check floor tool for blockages.
http://dysonmanuals.llc.nu/
Chris..
Dec 18, 2007 | Electrolux Lux 5500 Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
71 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
