Trying to re install windows, everything OK until process was cut off. now i'm stuck
  • JDTec
    JDTec May 11, 2010
    What OS? When did it cutoff? On a restart? Do you get any error messages?
Check your RAMs (Might any 1 of them is not functioning right or hung up during process
remove one of the ram and then try to install the windows
I have same problem once & i fixed that this way!
Posted on Sep 28, 2008
After Windows 8.1 update the scanner now gets stuck 25% through a scan - and just hangs.
If the printer worked with Windows 8 I would just go back to that.
For what it is worth, tried 8.1 and it was more trouble than it was worth so that is what I did.
Hope that helps.
Sep 21, 2014 | Office Equipment & Supplies
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
Stuck at HP INVENT after re-installing Windows 7 I thought i got some kind of virus so i decided to re-install Windows 7 Ultimate x64. Put the cd in and burn it, restart the computer and load the cd,...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 14, 2011 | Computers & Internet
When i turn on my computer i get a error message which says the computer started unexpectedly or encourntered an unexpected error.windows installation cannot proceed. hit ok to restart installation, hit ok...
you have to keep pressing f8 or f12 on start up untill you get a menu, there is a option in one of those menus to recover laptop on to restore windows the best previouse working order. try using your revovery cd and running from start the recovery process
Nov 29, 2009 | Toshiba Satellite A135-S4457 Notebook
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Problems booting up--no access to toolbars, etc. on XP
To resolve this issue, simple trick is, when it stands at the wallpaper without Start menu and Task bar, Press Alt + Ctrl + Del keys
Then select TaskManager.
In the Task manager, select Process Tab.
Under that select Windows Explorer process and select End
Again click on File menu in the same Window and select New Task.
Type Explorer.exe in the blank and click okay--OK
That should bring the complete screen.
Aug 04, 2008 | HP Compaq Presario V2000 Notebook
Start > turn off computer does not work on XP
Some process running in the background is not letting the system shut down. Use task manager to kill unnecessary processes before pressing turn off. If it shut downs then try to locate the process using taskmanager which is causing this problem.
Let me know if it helps.
Apr 13, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
