<p>It is important to back up your important files and
documents. This keeps your important components safety in case you accidentally
delete something or a computer virus will erase everything. Part of it is to
back up your emails and stores them on an external hard drive. It's a simple
process to save you a lot of frustration and give peace of mind nothing
catastrophic happens to everything on your computer <br />
<p>1. Open Outlook Express by double-clicking the program on
your desktop or click Start and select Programs. <br />
<p><br />
<p>2. Click Tools, then Options. <br />
<p><br />
<p>3. Click on "Store Folder" of
"Maintenance" link. <br />
<p><br />
<p>4. Copy the location using the right mouse button on the
mouse and press the "Ctrl" and "C", while the "Store
Folder" box. This is a shortcut to copy data. <br />
<p><br />
<p>5. Click Cancel to close the dialog box. Also note the
second dialogue box. <br />
<p><br />
<p>6. Click the Start button in the bottom left corner of the
screen and then click Run. <br />
<p><br />
<p>7. Hold the "Ctrl" and press "V" the
contents of your prints from the location of the memory stick, and then click
OK. <br />
<p><br />
<p>8. Click "Select All" from the Edit menu and copy.
<br />
<p><br />
<p>9. Right-click on the desktop and select New and then Folder
Options. <br />
<p><br />
<p>10. Right-click in the folder named "Mail Backup"
and press Enter. <br />
<p><br />
<p>11. Open the "Mail Backup" folder, double-click. <br />
<p><br />
<p>12. Right-click on the folder and select Paste. <br />
Instructions:<br />
<br />
1. Open iTunes on your computer. <br />
2. Plug the iPod USB connector into a USB port. Plug the other end of the connector into the bottom of the iPod Touch.<br />
3. Look for the iPod Touch to show up in the Devices column in the middle left corner of the iTunes program screen. Once it does, you have two options. You can have all the songs/music from your personal music library/file sync with the iPod Touch every time you plugged into the computer, or you can create a playlists and manually selecting them for syncing.<br />
4. Click on the iPod Touch symbol in the Devices column once you've decided which method of music management is best and suits your preference. A screen will pop up, giving you the summary of information about your iPod. Click on the options you want, then proceed to the bookmarked section labeled "Music" in the upper middle section of the page.<br />
5. Click the "Sync" button in the bottom right corner of the screen. When the music has finished its sync process, a message at the top will appear "iPod Touch sync is complete. OK to disconnect.<br />
<br /><img src="fossildude.jpg" />
Virus got your icons heh? OK, try this, click Ctrl+Alt+Del.. Hold the Ctrl key and the Alt Key, don't turn them lose until after you press the Del (Delete Key). If the task manager opens up (hopefully the virus has not disable it) then Click on the Process Tab and you will see everything that is running. Click on the Image Name in the very first column so that things will be in Alphabetical order. You want to see if explorer.exe is running. If it is click on it to highlight it, then press END PROCESS.
Next you want to click on the File at the upper left hand corner of the Task Manager window. Select the option New Task (run). Type in "explorer.exe" (without the quotes) and press OK. There's your desktop icons... Ok getting besides myself, but hopefully they will reappear unless a virus has them hidden. If they don't appear let me know and we'll unhide them.
In the upper Left-hand corner of your browser scrreen, Click on "File" (or type ALT-f) to get the File drop-down menu. Then select one of the 3 printing options: 1) Page setup 2) Print Preview 3) Print (Ctrl-P)
Alternatively, you could just type Ctrl-P (by holding down the "Ctrl" key then pressing "p") whenever you want to print the current page.
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
