Question about Maytag Neptune MAH5500B Front Load Washer
Washer spinning My washer started spinning and draing and then sopped and was making a loud squealling noise
  • 39 Answers
Hi jmm119
Its hard to say what it is but it could be one of 2 things, either the belt ore the main bearing is gone. but my first guesss would be the belt.
brent
Posted on Sep 29, 2008
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
My washer has started being loud when it spins out and is draing . I was wondering why. I wondered if something was getting ready to break.
Welcome to Fixya gojigirl,
Have you checked the pump to insure nothing is in there causing the noise, or do you believe it is coming from the main wash basket ?
I would rule out anything being in the pump first ( you can gain access in the lower right hand corner in the front by removing the pump insert/filter, you may need to drop down the small door in the toe panel at the bottom ) before declaring the main bearings or motor brushes being worn which can sound pretty loud, but usually just in the spin cycle.
Let me know what you find out.
good luck
macmarkus :)
May 09, 2010 | Bosch Classixx WFC 2465 Front Load Washer
MAV408DAWK Maytag top load washer is squealling
The noise could be coming from the wornout drum bearings. It needs replacement.
Oct 13, 2009 | Washing Machines
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
There is a squealling noise
THE SUPPORT AND SPIN BEARING IS BAD . WHEN THIS GOES BAD IT DESTROYS THE LOWER SEAL. MAJOR REPAIR . CHECK WARRANTY IT MAY BE COVERED. OTHER WISE REPLACE MACHINE.
FXIT
Dec 06, 2007 | Admiral AW22 Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
