Lg cm2077cw front load washer
How do you get to the power board, do you take apart the back if so how
is there anywhere I can find instructions on the net that will show step by ste;
  • wendykost Sep 28, 2008
    How do you change the power board on an LG cm2077cw front load washer
    Is there anywhere on the net that will show you step by step instructions
    Thanks
  • Anonymous Jan 27, 2009
    PF error code on my LG2077CW. I suppose I'll open it up and look for a fuse. Someone on this site said that a cotrol board can be replaced. Maybe I'll try that. I would appreciate any suggestions.
    Thanks,
Thanks for the support. Now that I know the board is gone would anyone know where I can find step by step instructions on replacing it. Also where can I purchase a board
Thanks
Posted on Sep 29, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
I have taken apart my drain pump but now i can't remember where the wires go on a lg front load washer
There are two connectors that attach to your drain pump, a black and a brown. They attach to the metal contact on the pump, it doesn't matter which one goes where, they are interchangeable.
When you put the front panel on, there is a door switch connector you need to attach before you put the screws back to hold it in place. After, the connectors on as you attach the top display portion of the washer. They are color coded, put the back into where the connector match with the size and colors on the main board.
Afterward, you can put everything back together and test the washer. Everything should light up and turn back on as normal before. Do not forget to put the particle filter trap back into the pump after everything is together on the bottom left corner of the washer or else it will leak lots of water when you do a wash.
Mar 19, 2011 | LG WM-2277HW Front Load Washer
My fronter loader LG is not powering up. My son put in a load before going to bed. When we woke up the next morning we realized the washer wouldn't power up and it had flipped the circuit breaker. I...
OK, let's try this: Open the door and (with an empty washer) give the drum a hard spin (either direction) by hand. This uses the direct drive motor to in effect become a generator, and should light up the control. If control lights up only momentarily, then no line voltage is getting to the display board. I would suspect the line filter first. Take the top cover off by removing the lower screws on the plastic clips on the back side of the washer's top. Stand in front of machine and use the palms of your hands to sharply push back on the L and R edges of the top, about 2 inches, then lift top off. Track power cord into washer and on to a small rectangular box. (the line filter, which contain a non-replaceable fuse) Check if power is going in and comming out (heading for the main board) If power in but no power out, replace filter. After the filter, the power goes to the main board, which is in the top back Left hand corner. It has a plastic cover over it. When the machine is powered up, there is a red LED on the board itself which lights up.
Note: on a working machine which is connected to power, you can do the drum spin and the display board will light and remain on, without touching the power button.
That's about as much help as I can do from here. If you need more help, I suggest you contact an authorized LG servicer in your area. (find one from LG at 800-256-0000)
These are very good machines. I know of one guy, runs 10 loads a day, 365 days a year through his LG. Can't say he's never had a problem, but he is very satisfied and probably does more loads each year than that old Whirlpool did in 20.
Mar 05, 2011 | LG WM-2277HW Front Load Washer
Need new pump - can't find the part number
the pump should be easy to get from your appliance store if you bring the model number with you . Its a pretty common fault and repair part
Aug 23, 2009 | LG WM1812C Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
DE shows-the door will not lock.I even took it apart.
door lock is not designed as a repairable item.just buy a new one.if it still dosent work,give the door an additional push.if it still dosent go ,brobably a fault with the main power board.(rare)
Feb 02, 2009 | LG WM-2277HW Front Load Washer
LG WM3677HW Won't turn ON.
Ok try this .
You say you know your way around electric. Here is the service manual incl drawings.
LINK
May 07, 2008 | LG WM-3677HW Front Load Washer / Dryer
LG WM2688H Front Load Washer has no power
You may have a failed control board and it will need to be replaced.
Oct 17, 2007 | LG WM2688H Front Load Washer
Washing Machines Logo
152 people viewed this question
Top Washing Machines Experts
