Question about Refrigerators
Rv refrigator ice maker repair
The water line from the ceniloid valve to the ice maker is split .how do i replace this line . this is in a CLASS A MOTOR HOME
  • NealF Oct 30, 2008
    Hose is rotted thru entire length and is routed in a sheath with a resistive anti-freeze wire. Problem is access. Does entire refer need to be pulled or is there a procedure for removing icemaker and routing new line from front? Which is simplest approach given wire and tube connection access requirements?
  • pilotwill43 Nov 09, 2008
    Does the unit need to be removed from the wall or can it be replaced with it in place. How is the line removed at top? I have the ice maker out and the line off at bottom. Thanks
    Problem Solver:
  • 3 Answers
You have to remove the frig..I just replaced my own hose. 4 screws in front..2 on bottom and 2 on top under the switch panel..2 in the rear on each corner.. disconnect the gas line (turn off the gas first) disconnect the power cord and water line...2 screwdrivers (one on each side) in back where you removed the screws. put them under the rails and push to start the removal.I used blocks of 2x4's laid in front of the frig stacked to the height of the bottom of the frig and then a piece of plywood. this will allow you to slide it out at the same level (it is very heavy). you will have to remove the tape that is around the old hose to save the wire that is inside. the water outlet is on top of the frig. repace the hose with normal ice maker plastic tubing from home depot and rewrap the tube and wire with electrical tape.put the frig back in in reverse...hope this helps
Posted on Feb 19, 2009
  • 943 Answers
Hi thanks for the question cut a piece of the faulty hose to a hardware store purchase a new piece from valve to the top .this should work thanks the appliance doc
Posted on Sep 28, 2008
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
Ice maker won't work
Before you replace the Water Valver -Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable item to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If Still not working, replace the water inlet valve at bottom back right of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Jun 05, 2010 | Sub-Zero 561 / F
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Ice maker don't make ice
Pour about 2/3 cup of water into the ice maker . If it dumps the cubes but doesn't refill with water , replace the water inlet valve , behind refrig , where the water line connects to on the refrig .
If it does not dump the cubes , and the cubes stay in the ice maker , replace the icemaker .
Oct 13, 2009 | GE Refrigerators
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Oct 10, 2008 | GE Refrigerators
Refrigerators Logo
310 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
