Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer continuouse water water runninng into tub
My washer continues to fill either a full stram or heavey dripping even when in spin cycle how do i stop this
  • 32 Answers
Try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Posted on Sep 28, 2008
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Water continues runninng into the washer even after turning off the washer
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 08, 2011 | Whirlpool AWM6100 Front Load Washer
On spin cycle the water wouldnt stop runninng in even when i shut it off.flooded my kitchen.it filled up and the door flew open.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.You need to replace the water inlet valve with this part.
Dec 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
216 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
