Question about Pentax Optio S4i Digital Camera
Optio s4i shutter lock up
Shutter locked up will not allow camera to power up more that a few seconds. Any thing that I can do or do I need to send in for professional help? Thanks Steve
  • txlingo Sep 28, 2008
    I will give it a try. I also checked out the Optio web site and discovered that some models like mine need a firmware download to prevent situation from occurring. I will keep my fingers crossed (not while working on it of course) Thanks
    eagle338, opened the camera up and it appears clean no trash visible? I guess service department next... Thanks Txlingo
  • 4,889 Answers
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken and needs to be sent in for proffessional service.
Posted on Sep 28, 2008
  • eagle338
    eagle338 Sep 28, 2008
    Yes looks like it needs proffessional service..
I just put a new 4GB SD card into my Pentax Optio S4i camera. When I power it up I get the message "memory card error" Tried another card and got the same error message. Any...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 02, 2011 | Pentax Optio S4i Digital Camera
Sometimes when I depress the shutter nothing happens for several seconds. I have to depress the shutter and the camera finally takes the picture. its does not happen all the time.
You need to press the shutter half-way and allow the camera to lock in the focus (it will beep) and then press the rest of the way when the moment is right.
Jul 03, 2010 | Canon EOS 40D Digital Camera
When I push the shutter button down, it takes 3 to 4 seconds before the shutter opens to snap the picture. What's with that ?
You need to press the shutter button half-way and allow the camera to lock in the focus before pressing the rest of the way.
Dec 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Shutter locked up while reviewing stored pics
Problem not solved at this time. However the Optio web site offers live chat. M-F 9:30 am to 6:30 pm. I will contact them to discuss later today. I will post their recommendations. Thanks Txlingo
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Camera not capturing
If it works in other ways, autofocuses, seems to lock on and is ready, but the shutter won't release,  and if when you turn it on, there's a buzzing sound for a few seconds, and if you turn on the AS button and when you press the shutter release part way you see five bars blinking on the right side of the viewfinder, you've got an AS system failure, and will have to send the camera in for service.
http://eservice.sony.com/webrma/web/index.do
Oct 03, 2006 | Konica Minolta Dynax 5D / Maxxum 5D...
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
S4i Foliage Problem
I would try Exposure Modes: Autum color, landscape & flower and see if any of them improve what your trying to get.
Problem in my Pentax s4i
This happens if you go from movie mode into green mode. If this wasn't the case with your freeze, it could be a problem with the memory card.
Pentax Optio S4i Digital Camera Logo
137 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
