Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Frigidaire refrigerator not working,no power
Hi, I move the refrigerator when still pluged in. the power went out, no light. no motor. please help
  • Bill Newberry
    Bill Newberry May 11, 2010
    Do you still need help with this repair?
    Thanks,
    Bill
  • 2006 Answers
SOURCE: frigidaire upright freezer repair
If all the lights are on, but the compressor isn't coming on, then I would check the compressor start relay and the start capacitor. If the unit was tipped or moved recently, you should not apply power for several hours or you could damage the compressor.
Posted on Jan 04, 2012
The Fresh food light and the display lights went out at the same time.
Thank you for your post, Gearld Beebe!
I understand that the light inside of your Frigidaire refrigerator and the display lights are no longer working. It sounds like you could be having a faulty wiring issue or power issue. You may want to have a technician come out to review your refrigerator to assure each component is getting the proper amount of energy or have a electrician come out to review the receptacle to assure it is providing accurate energy. I hope this information is helpful. -Matt
Dec 12, 2014 | Frigidaire Refrigerators
Why on my model FRS6LR5EW3 freezer side is working maintains ice but fresh food side is not working, no light, no fan??
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should, due to the fan not working. I also see that the light is not working, even after changing it out. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the light is on. Also, listen for the fan to run and give the refrigerator portion of your appliance 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
My frigidaire refrigerator ice dispenser stop working while in use. The control panel also stopped working along with both interior lights all at the same time. The panel is locked up with the number
Good Afternoon Randal,
I understand that your Frigidaire refrigerator, model# FGHC2345LF5, is having trouble with the ice dispenser, control panel, and both interior lights went out. I also see that there are numbers on your panel. If the numbers are showing Sb, this tells me your appliance is in the Sabbath mode. To get out of this mode you will need to press and hold the down arrow on the freezer side and the up arrow on the refrigerator side simultaneously for 5-10 seconds. If this does not work, I suggest resetting your appliance. You can do this by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and check the control panel as well as the ice dispenser and lights. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Refrigerators
FRIGIDAIRE FRS6HR4HW2 FRIDGE IS SOMEWHAT COOL BUT FREEZER IS SAME TEMP AS FRIDGE I HAVE POWER TO THE EVAP FAN BUT FAN IS NOT WORKING COULD THIS CAUSE THE FREEZER NOT TO GET COLD ENOUGH TO FREEZE
Yes, if your evap is fully frosted, and the fan is not working. The frosted evap will keep it cold but since the fan cant move the cold air from the evap it'll be cold, but not as cold as you'd like.
http://parts.sears.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FRS6HR4HW2/1428/0165000/R0607119/00005?shdMod=FRS6HR4HW2
there is the screen you need to order a new fan motor. option number 13 is the fan motor. lmk if u need more help!
Aug 05, 2013 | Frigidaire FRS26H5AS Side by Side...
FRIGIDAIRE FRS20ZRG STOPPED WORKING AFTER MOVING IT, LIGHTS STOPPED THE NEXT DAY
It may have been defrosting on a timed cycle when the compressor stopped. If any water was present at the time, it may have seeped into the electrics. Check the fuse and you have power to the on/off switch and thermostat.. If fuse blown, check all is dried out before plugging back in.
Apr 21, 2012 | Frigidaire Refrigerators
Frigidaire upright freezer repair
Jan 04, 2012 | Frigidaire Refrigerators
Refrigerator and freezer not cooling
if the light is working then it has power so it may have just went into defrost and it takes about 30 minutes to come back out / if it does not come by on within a hour then i also think you may have a bad temp control / larry
Nov 30, 2008 | Frigidaire FRT18S6AW Top Freezer...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Kenmore refridgerator model #50522100
Is it still working..If so it probable doesn't have a problem.My guess is that it went into the defrost cycle.When you unpluged it in 2003 it was time for the defrost cycle, so when you pluged it in it went into the cycle..
Sep 28, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
