Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint WD72 - Plug Fuse Blows on Final Spin/Rinse
During final spin/rinse a vibrating/buzzing noise begins behind the fron panel and which appears to be coming from just to the right of the soap drawer. After a few seconds, either the trip throws on the household consumer unit, or on one occasion, the fuse in the main splug blew as well. Have noticed (don't know if onnected) that soap drawer is often found containing water after machine is finished.
Turned out to be the motor. Discovered this by running the machine through a cycle with the top and rear panels removed so as to watch what happened. On fast spin there was a bang, a big blue flash from the back of the motor and the house electrical trip tripped out. Reset trip, restart washing machine and it worked find again until fast spin. Ordered a new motor on line from UK White Goods, fitted it and all is right as rain.
Posted on Nov 04, 2008
  • 750 Answers
Hello thesquiffys
Welcome,
You said,
During final spin/rinse a vibrating/buzzing noise begins behind the from panel and which appears to be coming from just to the right of the soap drawer. After a few seconds, either the trip throws on the household consumer unit, or on one occasion, the fuse in the mains plug blew as well. Have noticed (don't know if connected) that soap drawer is often found containing water after machine is finished.
1.The soap dish needs to be cleaned out, holes clogged. The instructions for this
process is in the user guide and I'll paste the site below for you in case you do not have it available to you.
2.The noise sounds like a short or electrical problem starting.
For this you will need a hands on diagnoses.
TRY doing the soap drawer first to be sure that it is not the culprit!
The book can be found here and the drawer info on page 12:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWD72.pdf
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank You
Posted on Oct 17, 2008
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
The front Load machine does not spin the excess water fron the wash on the final rinse. If I set the spin cycle again, it works ?
Most all front load machines have a pump filter. If the bottom front panel is removable, remove and unscrew filter. Clean filter
Nov 07, 2009 | GE Washing Machines
Washing machine won't spin
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Jan 28, 2009 | Washing Machines
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
225 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
