Question about Sony Playstation 3 (PS3) Console
Menu will not show up
The main menu will not show up. It is just an orange screen. Can I reset the entire console or anything like that?
  • cmfinbizzle Sep 28, 2008
    I turn on my ps3 and the menu screen does not come up but the screen blinks so i no i t is gettting a feed
    Champion:
  • 207 Answers
Yes you can!
TRY THIS cmfin and trey!
Shut the system off in the back then un-plug and re-plug all cords.
Turn the power on in the back.
The ps3 should have a red light on in the front.
Push and HOLD the power button in front!
It will go through a red light to green beep at you then go back to red.
This should HARD reset it.
If you have ever changed tvs or played on a different tv the ps3 will sync itself to that tv.
SO a regular tv is different then my hdtv so it would need to be reset to play on a different tv!
I hope it helps!
Posted on Sep 29, 2008
My gamecube will turn on to set the settings, after I set them I put in a disc and then the power shuts off. I have two sets of power cords I tried them both and it does the same thing with each of them.
  • System settings were lost:
    You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
    1. From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
    2. Press the A Button to display Calendar Menu choices of Date or Time.
    3. Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
    4. Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
    5. Press the A Button to accept your choice.
    6. Press the B Button to return to the Calendar Menu or the Main Menu.
    7. Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
    If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
  • Feb 24, 2010 | Nintendo GameCube Console
    Hand does not show up on menu
    The main unit is not receiving the signal from the remote,
    It can be a couple of things...
    More than likely you have two remote handhelds. You may be using the wrong handheld to choose the options. Try the 2nd handheld.
    Check to make sure the batteries are charged and handheld is ON
    Make sure the receiver is in plain sight and not blocked
    Aug 07, 2009 | Nintendo Wii Console
    Nintendo game cube says an error has occurred,said to turn it off and check the instruction booklet
    Is it the game or the game cube that is doing that. If it is the game then it is probably scratched. Try using toothpaste to clean. If it is the game cube that is broken then open it up and see if anything looks broken
    Jul 14, 2009 | Nintendo GameCube Console
    PS3 only goes to game screen it locks up doing anything else
    Does This Go with The Friends List Aswell bcuz if it duz i will reset my box and see if that duz anythin
    Mar 29, 2009 | Sony Playstation 3 (PS3) Console
    When I turn on the Wii console freezes in the main menu screen.
    Try the Wii "RESET".
    Here's how:
    1. Unplug the Wii for at least 5 minutes.
    2. Plug it back in.
    Dec 27, 2008 | Nintendo Wii Console
    Can't play any games.
    Hi!if the problem is recurring with other games then you will have to call Sony as it looks like a hardware error mostly in the lens mechanism..do u get an error code?i had the same problem and had to get the lens replaced..if your console is under warranty do call Sony..al details will be on the playstation3 site..hope it helps!
    Nov 26, 2008 | Sony Playstation 3 (PS3) Console
    No display problem
    You might have the broken LCD.. If you not sure, try to boot under recovery menu - (if you have custom firmware installed). if the problem come from corrupted firmware you should see the menu of recovery.. then goto menu "Advance" > "Format flash1 and reset setting". otherwise you may consider sending it back to Sony for repair.You can call SONY support at 1-800-345-7669.
    hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER. http://e-arena.blogspot.com.
    Nov 25, 2008 | Sony PlayStation Portable (PSP) Console
    PS3 - No main menu
    Contact Sony @ 1-877-253-SONY(7669) for a replacement unit as this is not normal.
    It autoplays games but no main menu eh?
    Sep 08, 2008 | Sony Playstation 3 (PS3) Console
    Playstaion 2
    can you go into the browser ?
    can you view your mem card?
    You can try the auto-diagnosis. heres how
    Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
    or try cleaning the lens and games
    Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
