Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Sears 10 hp b/s rididng mower
Electronic ignition. Batery charged. Will not turn over ( DEAD)
Yellow wire unattached from under engine but can't see where to attach
  • shaylasdaddy May 11, 2010
    craftsman 18hp 42cut disengage clutch motor dies
    LT1000 engine stops when you disengage clutch
    Scholar:
  • 62 Answers
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse.
Hope some of this helps.
C
Posted on Oct 08, 2008
70's sear boat motor made by Tecumseh.no spark after engine replaced.new electronic ignition coil plug spark had units tested and got lawn mower guy shock.they are good.ign fixed mount/no screws
most likely a bad ground somewhere between the coil and the engine head. no ground no current flow a shock would be because he wqas touching the engine and plug wire or plug
Mar 01, 2015 | Garden
Sears tractor wiring diagram charging system
google your model # (usually found on label under the seat). This should take you to sears site. click on manual tab and download the users manual. wiring diagrams should be in the manual.
Jul 25, 2013 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Sears ride on mower acts like a dead battery but battery is charged
Clean all the large wires to the battery and to the Starter solenoid
Jul 22, 2013 | Sears Garden
1999 Honda Accord New battery Alternator checked at Auto Zone and Advance auto put alternator back on car still batery still goes dead in about 30 miles
Yes you could have an ECU problem but there are a number of tests that need to be done. I have found in a couple of the accords to be an open wire. Below is a picture of the connector at the alternator. Unplug it and turn the key to the on position (make sure your battery is fully charged) check the number 1 position of the plug. There should be battery voltage there. If there isn't you need to locate the open black & yellow wire. That wire should go directly to the fuse box inside the vehicle. This has happened a couple of times in my shop. You could have other problems but would try this first. If all is well with this tests feel free to email me at csautomotivecars@att.net with all your information and I will be happy to give you some other tests to perform in order to narrow down the problem. No there wouldn't be a charge for my help, don't mind helping when I can. As long as you can kinda follow and locate wires/connectors and have a digital volt/ohm meter (and know how to use it) I think narrowing down the problem will be fairly easy. On this picture I am going by that you have the most common engine (4 cylinder 2.3) If you have the DV or LX model with the V6 3.0 liter engine there may be a difference so this test might not be correct. Was just going with the common engine. Hope this helps......
May 20, 2012 | 1999 Honda Accord
Just stopped, put in gas, turn key...NOTHING
If it has a Briggs and Stratton motor open the hood and look all along the wire harnesses. There might be an automotive type plug in 20 amp fuse that has blown. If it did blow there is a reason. First look for a dead short somewhere. Mine was a loose wiring terminal at the headlight. Replace fuse and try to start.
May 01, 2010 | Sears Lawn Mower Ignition Switch Replaces...
Had dead battery in 2002 honda civic got jump now word CODE in radio display
try disconecting the positive terminal of the batery for sevral minets (5-10) this will reset the brain box memory for the stero aswell as for the car it self.
what caused the batery to go dead in the first place?
things that i can think of :
1) left headlights on over night
2) bad altenator not charging batery
3) battery is old and not taking a charge anymore
4) new stero installed incorectly and drainging the batery
have you resently installed a new stero or amplifyer?
is the turn key igntion system hooked into the amp/stero antena lead so that thy are shut of when the ignition is?
of note: new streo >theres a blue wire marked ant that goes to the amplifyer if not there you need to find the orange accsesory wire coming from the turn key igntion>check for power when ignition is in the on & off states could be yellow in some cars but is usaly orange if this wire has on and of state controled by the turn key igntion this would be the wire to tap into for the amplyfire and the radio main power
check your radio's instaltion guide for code errors
its posible that when hooking up the jump it was done incorectly and blew up the radio
ie postive and negative where fliped
hope this helped :)
Feb 24, 2010 | 2002 Honda Civic
CIGAR LIGHTER WILL NOT CHARGE UNLESS ENGINE
Some cig lighter plugins are wired directly to battery, others are connected to ignition. You can always re-wire it straight to fuse or radio memory wire (Yellow) on cd deck or (Green/Black) from car wiring
Nov 12, 2009 | 2004 Jaguar XJ-Series
Mower wont start
Solenoid has dead short. Replace it. Cost is low. Crossing terminals on today's engines with electronic ignition parts is dangerous to the other parts.
May 24, 2009 | Mtd Garden
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
If it's not up near 12 volts, you have a dead cell and need a new battery.
May 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
229 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
