Question about Samsung HCM5525W 55" Rear Projection Television
After 45 min, Screen gets hazy and with green artifacts on the right of objects
Hi, this looks like an excellent forum for techs. I am a big DIY, but never attempted TV repair. Well here's my problem:
I just adopted a TV from a friend, and it is messing up on me. It starts up just fine (maybe a little green tint, but almost not noticeable). However after 30 minutes (around 45 minutes), the tv clicks and the tv gets all hazy. I'm including some pictures so you can see the difference between my startup case and the case where it gets hazy. If you have somewhere I can start, I'll gladly attempt it on my own. Let me know if there is any safety concerns I should be worried about as well. Thanks!
  • 8 more comments
  • ETdoFresh Sep 28, 2008
    Oh yes, here's the info on my TV:
    Samsung
    Model No.: HCM5525W
    SVC MODEL: HCM5525WX/XAA
    AVC 1209 60Hz 230W
    I know the pictures are not as professional as I would like to have taken them (with my cheap little digital camera). But I think it got the issue for the most part.
  • ETdoFresh Sep 29, 2008
    UPDATE: Now it is really intermittent. It almost never goes back to clear anymore. Just a green artifacts all along objects on the screen. Hope you can see it in the pic above. Thanks! - ET
  • ETdoFresh Oct 02, 2008
    Thanks justuscc, I'll give that a shot and let you know how it goes. I googled it, and one of the first featured sites had it for $7.99 each, where I payed a total of $22.93 for two chips with shipping and 6-month warranty.
    I got it here:
    http://www.suburban-elect.com/display/ST...
  • ETdoFresh Oct 03, 2008
    Well, I bought the STK392-040 as recommended by justuscc, and i'll try replacing that. But as I wait for this product to ship, i decided to take out the board. I'm having some trouble taking it out b/c 2 wires don't unplug, but that is besides the issue. I was looking on the board, and I notived this:
    Two things look like crushed plastic... I'm not sure if this is "normal" or something that may have fried. What does this look like to you?
    But closer shot maybe:
  • ETdoFresh Oct 04, 2008
    Just added some more comments. Someone please check them out! Thanks!
    Last thing (I hope, haha). Any idea how to take the wires off this little black box?
    Far view
    Close View
    Thanks!
  • ETdoFresh Oct 11, 2008
    FINALLY! It's fixed! Here's my part list and my procedure:
    PARTS LIST
    - Phillips Screwdriver
    - Soldering Iron and Solder
    - Desolder pump (Solder ******)
    - STK392-040 x 2 (2 Convergence ICs) $7.99ea
    - 100K POT x 2 (2 Variable resistors that are 25% and 0.3W) 2 for $1.00
    PROCESS:
    - Take off bottom back panel (where all the input connections are)
    - Unplug all cables from center board (remember/jot down what goes where)
    - Unscrew and take out the center board from television (there was one wire I couldn't remove, so I had to set the board just outside the television to work on it).
    - Unscrew STK392-040 from heat sink and remove heatsink
    - Desolder both STK392-040 and both burnt/fried resistors (RR402S and RR471S)
    - Solder new STK392-040 in, and solder two new POTS... set RR402S close to 100K and RR471S close to 50K
    - Put everything back, turn on TV.
    - Run "Perfect Focus" once, and enjoy!
    PS - If screen seems to big (doesn't fit in the TV frame, mess with the variable resistor settings). I believe RR471S was the size of the screen, and RR402S was the trapoid of the screen, but unsure.
    Thanks for your help justuscc and fixya.com... i would have had no idea where to start without y'all! Here are some more pictures! YAY!
    Overall picture of the center board pulled out
    Old and new convergence ICs
    Old burnt grey resistors and new blue resistors on board
    Everything works, thanks to the techs that helped me!
    - JUSTUSCC
    - WELCOMEJEE
    - Ack, forgot the last tech, but started with an O i believe, so, thanks OCHU (sorry, thats the name I'm giving :)
    One last comment, I tested the variable resistor with a multimeter, and it looks like they are still absolutely fine! I thought they were burnt, but I think welcomejee is right, it looks like one is set at 97.1K and the other is at 48.6K. So just becuase they look all messed up, it probably really is just glue.
  • 10,594 Answers
These are two variable resistors has some glue on it for protection, means NOT to adjust it as already adjusted in factory.
now regarding pulling two wires, one thick wire can be pulled ( not in all cases) as shown in below picture. Push it and rotate it. If this not works, don't pull it force ly. just go to other end of this wire and try this method.
LOL, my drawing isn't good :P
Posted on Oct 11, 2008
  • Shahid Electronics
    Shahid Electronics Oct 11, 2008
    Hey Congratulations on fixing your TV. :)
    You really did great job and thanks for feedback with pictures.
    Have nice time.
    Sergeant:
    Champion:
  • 435 Answers
Do you hear any wierd sound when its hazy ? Try muting the TV and see.
From your description it sounds to me like voltage fluctuations.
If not externally, it might be internally.
Since this happens after a while, I believe this problem should be associated with a capacitor.
There should be a faulty capacitor inside which needs to be replaced. This is safe to be done by a technician.
And yea, it does not sound safe to use the TV when this happens.
if you still want to go by "DIY".
Try opening the TV and look for any burnt capacitor inside.
Posted on Oct 02, 2008
  • 360 Answers
Well in most cases it is two IC`S the part number is STK392-040 these parts are soldered into the board. good luck
  • Jimmy
    Jimmy Oct 02, 2008
    also be carefull there are small resistors next to the ic you might need to test them after you resolder the ic's
  • Jimmy
    Jimmy Oct 12, 2008
    thats great good to hear its fixed....... justuscc
I have a hazy screen
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Philips 55PW9363 55" Rear Projection...
I have a Phillips TV Model No. 46PP93 0217. The
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Philips 46PP9302 46" Rear Projection...
Hazy and messed up color
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
7P5441 C101 54in color is wrong
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
HI, I HAD TO UNCLOG MY PUMP ON A MAYTAG NEPTURE TOP LAOD WASHER TODAY, EVERYTHING WENT OK UNTILL I WENT TO FINISH AND I SAW THERE WAS A GREEN WIRE THAT WAS NOT HOOK TO THE PRESSURE SWITCH I DONT KNOW IF IT...
Hi SandI,
Your machine is a FAV6800A correct?
If so looks to be Cabinet Ground connection to unused connection on the pressure switch as the schematic shows. See attached schematic Pic. If you open up the rear console three # 15 Torx screws on the rear condole the schematic should be inside for your machine console.
I’ll try to take a pic of the connection I see on the pressure switch. From what I see no big deal to let it hang if this is the green wire in question. Do you see two green wires on the connector that is hanging?
Excellent DIY job on Drain Pump clog a tight work area for sure. I have a Sump Cap DIY Filter I made if you are interested I will post a pic. Stops coins and other items from working there way down to the pump impeller.
Here is a screen snap of the schematic showing the connection point on the Pressure Switch……Rich
Jan 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
You can see some example photos and find a solution here...
Nov 28, 2009 | Televison & Video
My screen has 3 black large artifacts at the bottom and corner
I believe those objects are really black, and always there, Maybe they are no so big as they look, but the projection make them looks that big. some times the plastic use in the manufacturing is not cleaned and those plastics felt in the lenses, being positive. an expert can decide if it is just and object or anything else.
Apr 24, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Double picture & color problem
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Mitsubishi WD-52825 Noise issue
Good Day, mooredriven;
If the picture looks like checker board pattern the TV may have a problem with part:
D8F00 PART # 264P828010-diode-DAN202U/MA142W
D8FO1 " " " " "
C8F26 " 141P148000 CER (B25K-1M-K)
C8F29 " " " "
OR the formatter board #930B924001, on that board there are 5 caps 1000 ufd 35v that commonly go bad.
Good Luck, big irish.
Jul 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vertical green line somthing like an artifact
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 28, 2008 | ViewSonic VA1703wb Monitor
Samsung HCM5525W 55" Rear Projection Television Logo
257 people viewed this question
Henry  Thomas
Henry Thomas
