Question about Olympus Cameras
I have an Olympus MJU 700 but the flash is not working
    Sergeant:
  • 208 Answers
I want you to check these,
Check that batteries are fresh.
Check that camera hasn't been set for no-flash mode.
Give the flash time to charge before pressing shutter.
Try to reset your phone by MASTER RESET(Factory reset) by referring to your manual.
If you updated the firmware for your camera, then that update can also be a reason for your flash not working. so try installing the firmware which was present when the camera was working good.
check there is any debris in the hot shoe, there is a switch on the left that stops the pop up working when you put a external flash on.
If you have been using a speedlite or another flash on the hotshoe lately, there is a little metal strip in the hotshoe (rail) that disables the pop-up built-in flash. So, this little metal strip goes down when you slide in an external flash and disable the built-in flash by breaking an electrical contact. This little metal strip has the occasional tendency to get stucked down after unmounting your speedlite, which results in the behavior you are seeing. Just turn OFF your camera and use a toohpick in the hotshoe and force very gently the metal strip up to make the metal strip goes back to its original position when there is no speedlite mounted on your camera. Compare both sides in the hotshoe (rail). Turn it ON and there you go!
Hope my info solves your problem,
Thanx for using fixya,
Cheers.
Posted on Sep 28, 2008
How do I turn the flash off on Olympus mju digital 600 (I have lost the instruction book)
You can download a copy of the user manual from here:-
http://www.olympus.co.uk/consumer/208_manuals.cfm?prodID=archive
Its almost at the bottom of the page.
Mar 29, 2010 | Olympus ? DIGITAL 600
How to activate panorama?
Panorama shooting lets you create a panoramic picture, using the OLYMPUS
Master software from the provided CD-ROM. An Olympus xD-Picture Card is required for Panorama shooting. If the card is a Fuji xD card then the panorama feature would be disabled to you.
May 24, 2009 | Olympus Stylus / mju 1050 SW Digital...
Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
Apr 08, 2009 | Olympus mju 740 Digital Camera
MJU 300 battery charged .slide open no power
This may be a repair issue with the sensor that is located behind the front sliding lens cover. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Feb 11, 2009 | Olympus MJU 300 Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Stylus 700 error D:5f08 5e02
The error message (D: 5f08 5e02) means that your lens is dying / dead. It just happened to mine (on the Mju 700, but it's the same thing) and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Dec 22, 2008 | Olympus Stylus 700 / 700 Digital Camera
Diplay turning white on mju 700...
Hi
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
Thomas
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Oct 12, 2007 | Olympus MJU 400 Digital Camera
Olympus 300 mju
well sometimes that happen, and can be two things 1st the camera got very wet, or the button inside got broken and needs to be replaced.
Feb 09, 2007 | Olympus MJU 300 Digital Camera
Cameras Logo
172 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
