Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
WEP Password I'm Trying to set up Xbox live for my 360. It's asking for my WEP Password, but the company that has it wont tell me it. how do i find out the password because if i don't I'm out over 100 bucks! Thanks
  • Anonymous Dec 20, 2008
    my x-box live wants a wep but I don't know it. Help.
The wep password is set up by you!
Posted on Oct 12, 2008
My xbox live account wont accept my windows live id password ?? contacted microsoft and they made me delete and try to recover my gamertag . but on trying to do that it asks you for your password you used...
First, make sure you're typing in the password exactly how you think it should be. The on-screen keyboard can be tricky, especially if you're using the awful Xbox 360 D-Pad to navigate it.
If you're sure you're typing it right and it's not being accepted, it's possible that you're remembering the wrong password. Microsoft has a nice walk-through of how to recover or reset your password when you can't remember it which can be found here.
If for whatever reason that doesn't work, just cycle through every password you can remember that you've ever used. Maybe you'll luck out and get it.
Mar 21, 2011 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
Where can i find my wep key
Your WEP key is the password on your wireless internet connection.
Whomever set up your wireless internet connection (wifi) should be able to provide the WEP key for you.
Aug 06, 2010 | Microsoft Xbox Live One Month Gold...
Where can i find out what my wep key is?
the key is in the flash memory of your router and that is usually inaccessable. you should reset your network (router, possibly modem) to the default/factory settings, then set up everything as it was and try again.
Oct 27, 2009 | Microsoft Xbox 360 Console
Trying to connect to xbox live
go to the "connect to xbox live" prompt, make a profile and then follow each step
F.Y.I. every xbox 360 has 3 free 1 months on it already. when it asks you which membership you want, 1 month up to a year. go to the one on bottom "revert to silver", it will automatically give you a free 1 month gold membership for your gaming pleasure and you wont have to give any credit card info.
Sep 25, 2009 | Microsoft Xbox 360 Console
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Dec 31, 2007 | Computers & Internet
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
127 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
