Question about Fanstel Caller ID Box Phone
Cidco inc caller id box - model # JA-25A-18
How do you change the time & date on a cidco caller id box? It only has 3 buttons - delete & . When you push the button you get no calls -- delete buttons does nothing. Please help - 1st time using this!
Thanks,
Misty Lampani
Southern Telecom Large Display Caller ID CID 50LD manual
Set Date and time manually if desired. 1. Press and hold the [dial] button until the display show "SET left OR right ". 2. Use the up or down buttons and select "DATE/TIME" andpress the [dial] button to enter.3. Use the up or down buttons to set the hour, minute, AM/PM,month, and day.4. Press the [dial] button to confirm your selections
Nov 28, 2013 | Southern Telecom Large Display Caller ID...
Describe your cidco cw99 caller id+ user manual Problem I want to delete old data, set all to 0 calls. I don't have a user manual ! Thanks.
Hi drkossvt,
The way to erase all calls on the cidco cw99 caller ID is to arrow into the caller ID list and hold the Delete button for about 6 seconds. The screen will display "- NO CALLS -"
Note: it does not matter which Caller ID entry you arrow to before you hold the Delete button. This also works if you are on the "- END OF LIST -" screen.
If you want to delete a single call, arrow to that call and press the Delete button twice.
Feb 12, 2011 | Home Security
I need cidco model#sa-60a-10 owner manual
Here is a link to Fanstel's website where there is contact info for the company: http://www.fanstel.com/cgi-bin/products.exe?CallerID. The picture you provided looks like model B72S on their website. The following link gives information on resetting the B72S caller ID unit:
http://www.fanstel.com/cgi-bin/search.exe?search=B72S&products=on&faqs=on&pages=on.
Hope this helps.
Jan 19, 2011 | Fanstel Caller ID Box Phone
Cidco caller id model SA-60A-20 how do we change the language on it
I was able to reset my GTE Cidco SA-60A-20 caller ID unit with the following procedure:
1. Remove the battery.
2. Wait several minutes after the display fades away.
3. While holding down the "Delete" key, reinsert the battery.
4. Release the "Delete" key.
5. The unit will come up showing a boot process and end with a screen allowing you to choose the English or Spanish language.
Sep 21, 2010 | Cell Phones
How ddo I change the date?
The time and date will update automatically when you receive a call as long as you receive caller id from the telephone service provider. Current time and date are part of the Caller ID data stream. Once the time is received the Fanstel unit will keep time from there and it will be updated every time you get a new call.
May 09, 2010 | Fanstel Caller ID Box Phone
Need to reset date and time on caller ID on Durabrand phone Model #5562
Hold down the Delete button and press the Down button. LCD settings show. Keep pressing the Delete button until you get to Hour and Minutes. Change the hour and minutes, then keep pressing the Delete button until the screen is normal again.
Hope it helped.
Nov 19, 2009 | Lands Phones
How do I change from Spanish to English on my caller ID screen? Cidco Model# SA-60A-10
Nov 19, 2008 | Lands Phones
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
Sep 29, 2008 | Home Security
How to change area code/prefix on USWEST CIDCO CT-200
Hold down the two review buttons for several seconds until it asks what language you want. Once there, you will be presented with a series of questions, followed by two choices. The left arrow button is for the choice on the left; the right arrow button is for the choice on the right. I chose "no" for 1+ dialing, and when I got to the place to enter my area code, I used the numbers on the keypad to enter a nonsense area code. Now the caller ID shows area codes. This was the best I could do, since the manual is long gone.
Jul 13, 2008 | Lands Phones
Fanstel Caller ID Box Phone Logo
229 people viewed this question
Top Fanstel Lands Phones Experts
Raphael Josiah
ray gallant
Are you a Fanstel Lands Phone Expert? Answer questions, earn points and help others
