Question about Dryers
My new LG DLG37744W gas dryer won't heat up and there is a smell of gas in the chamber when the door is opened.
  • 1,543 Answers
Turn gas supply off to dryer, air out room, seek warranty service. Don't mess with gas.
Posted on Sep 28, 2008
Lg dryer dlg5966w wont heat, smells like gas in the drum
I have same problem. I have tried everything. Even new control board. It only intermitantly does this. When it fails to light it pumps raw gas. Only thing to try next is new ignitor.....
Jul 17, 2012 | LG D5966 Gas Dryer
My LG TROMM DLG2526W dryer is not heating.
Check thermistors. Two in heating chamber and one or two in fan housing. Clean surfaces and check for continuity.
Aug 17, 2017 | LG DLG5932W Gas Dryer
To stop gas smell after opening dryer door
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer will not heat and I can smell gas when I open the tub.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Can't get heat from our gas dryer. LG dlg3788w
my model number is lgr4634eq1. my gas dryer just spins but does not heat. The dryer came w/the house 3/13/98..
Feb 01, 2010 | LG DLG3788W Gas Dryer
Gas Dryer DLG5966W pilot light
The power should turn on a electric igniter once the gas has reached the heat chamber and regulator. If not let me know soon the model number of your LG dryer so I can help you better, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 09, 2009 | LG Dryers
Gas dryer no heat
defective gas vavle..replace
Feb 09, 2009 | LG DLG5932W Gas Dryer
LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Jan 03, 2009 | LG DLG5932W Gas Dryer
DLG5988W Gas dryer
you might want to check you venting, if tis not clear, your lint might be building up inside machine and burning off as you use your unit.
Mar 01, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
