Question about Dryers
Drum wont turn - Dryers
  • 943 Answers
Hi. thanks for the question . i would check the door switch ,to see if its making contact. check power supply .you need 240 volts check that . belt could be broken . check that . the appliance doc
Posted on Sep 28, 2008
Put new belt on dryer but it wont turn and i can smell burning and the drum wont turn
sounds like the belt may be bound somewhere, I would take it back apart and see if I can turn everything by hand. If everything turns freely then I would reinsert drum, hook belt up and see it I could turn the drum with my hands, it will turn but not to freely. Hope this helped tim
Sep 19, 2010 | Dryers
Drum wont turn
It could be a bad motor...or it could be a problem with the timer switch...both are near a $100.00 to replace...Good Luck
Apr 04, 2010 | Bosch Dryers
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
PS2 drum kit wont turn on
the drum kits are very unreliable and breakable. You might need a new one.
Sep 30, 2009 | Activision Xbox 360 Guitar Hero II
Belt broken, drum wont turn manually
if your drum will not turn manually, then the motor is seized up, or a sock is caught in the blower wheel...
Sep 15, 2009 | Dryers
WONT DRY,DRUM WONT TURN
This sounds like the motor that drive the drum has packed it in could be the capacitor or the centrifugal switch cant say with the amount of info given. I am quite sure it is with the motor as manually turning it is assisting with the start up of the motor
Aug 18, 2009 | GE Profile Harmony DPGT750EC Electric...
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Dryers Logo
96 people viewed this question
Top Dryers Experts
