Question about Hasselblad Cameras
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Hi,as i said earlier 1,2 and 4 speeds of a hasselblad 80mm cf T* work like 1/30.The B and the rest of the speeds seems to be ok...has anyone any ideea?thank you
  • 667 Answers
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Posted on Oct 02, 2008
This is not a problem necessarily, but i cant seem to find this info on the net. what type of lens is compatible with the Hasselblad 553 ELX? Can the 500 C/M lenses work?
All C and CF lenses manufactured since 1957 will work on your 553ELX. The only Hasselblad lenses which will not work are the F types manufactured after 1976 for those bodies which incorporate a focal plane shutter.
You can download a free user manual courtesy of the Norman Butkus website by clicking here.
I hope that my reply has been clear and useful, if so then please spare a moment to rate my answer.
Aug 02, 2011 | Hasselblad 553ELX Medium Format Camera
I pressed the shutter release button while attaching the lens to the body. Now my Hasselblad is jammed. The diaphram is closed, the shutter crank knob is turned about halfway, and the lens is stuck half...
On my Hasselblad 501 CM, I have never encountered this problem. As expensive as these cameras are, and delicate, I wouldn't chance it. I would contact the Hasselbad company and ask them to fix it for you.
http://www.hasselbladusa.com/service--support/technical-support/contact.aspx
I would try the above link to contact hasselblad's tech support if I were you.
Good luck on this.
Dec 25, 2010 | Hasselblad 501CM Medium Format Camera
Planar 80mm T*,wrong 1,2,4 speeds
I have been repairing Hasselblads since 1991. I can tell you that removing the shutter for repairs is a time consuming task that requires patience and tolerance. All of the screws are flat blade, nine in particular that are hard to reach without the proper set of drivers.
The shutter has a gear train that needs to be cleaned and lubricated to fix the lower speed problem. It is common since they are rarely used in commercial work
Sep 23, 2009 | Cameras
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
Lens not stopping down
sometime it may happen, put the camera body without lens put it on the speed of b see when you klick the camera the shutter will go up and also mirror then the body is ok , put the lens sapratley you will see one small part is over the mount when you rotate it the lens appurture is opened and close u can put the f2.8 the ere is closure of appurture when you move the knob like wise u change the app and vise versa
Feb 09, 2007 | Hasselblad 80mm f/2.8 CFE Lens
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Cameras Logo
319 people viewed this question
Top Hasselblad Cameras Experts
Michael Galve
Michael Galve
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
