Question about Car Audio & Video
Thump THA-1000 compatability with GM stereo
Dear Guru,
We are trying to connect a Thump THA-1000 audio amplifier in between the rear speakers and the stereo output on my sons 2000 chevy blazer. When we just touch the center conductor of the RCA plug to the jack we get audio but when we press it in further and the outside of the plug touches the outside of the jack, we loose all audio, even the audio going to the front speakers which we haven't touched.
Do you think we have an impedance problem or could it be something else?
Are Thump amplifiers still manufactured? If so, do you know of a website for the manufacturers?
Thanks,
Rick
  • rmarkiewicz Oct 04, 2008
    Ended up purchasing a $20 Ground Loop Isolator from the local electronics store and placed that between the car stereo output and the amplifier input and that solved the problem.
    Thank you very much for sharing your wisdom!
  • 631 Answers
If you're using the speaker output of the head unit, you need to use either the high level input (if the amp has one) or use a Line Output Converter (LOC). The LOC is generally a better option.
I don't know if they are still in business.
Let me know if you have any other questions.
Posted on Sep 29, 2008
  • Perry Babin Oct 04, 2008
    The GLI is doing basically the same thing as the LOC would have done. They both have isolation transformers. The main difference is that the LOC reduces the output signal level from speaker level to preamp level.
Yamaha R-S700 has no audio all channels, it will power on but no audio on any channel.
Have you checked all your speaker connections? And your Speaker selection a-b? If yes then Does your volume indicator show the volume increase when turning the volume up? If so, then try a different speaker . To check your speakers you can take a 9v alkaline battery and momentarily touch the leads to each speaker after disconnecting them from the stereo(black is ground and the striped wire is positive) You should hear a thump from the speaker.
Or just check them with another stereo or sound source. If the speakers are ok then you have a problem with the amplifier section of the receiver. There are no fuses internally in the Yamaha RS-700
Oct 03, 2014 | Audio Players & Recorders
How to connect audio from TV to Hi-Fi for stereo speakers
Most of the TVs are having an analog audio or digital audio output.
However, it is not possible to connect direct speakers to it.
It is required to use an amplifier/receiver to connect the speakers..
You can also connect PC speakers (like 2.1 and 5.1) using a compatible cable as it has built in amplifier.
Please get back to me if you need further assistance. www.fixya.com/users/shajanrs
Jan 17, 2011 | Televison & Video
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Pioneer GM-6200f amp no audio - flashing light
Hello! Yes, It certainly looks like the output power circuit has blown.
I wish I had better news.
Guru................saailer
Jan 12, 2010 | Pioneer GM-6200F Car Audio Amplifier
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Apr 29, 2009 | Car Audio & Video
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Is that ok to do mono on Thump TA1001
yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Aug 08, 2008 | Thump TA1001 Car Audio Amplifier
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
