Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick.. the screen on my sidekick is half white and the other half works wat does that mean
  • thea7861 Oct 09, 2008
    my sidekick id will only show half of the screen
    what do i do?
    President:
  • 625 Answers
It may mean that that the connector to the lcd is loose.
Try following this procedure and see if it fixes it.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Other than that a new screen would work.
Posted on Sep 30, 2008
The screen wont come on my sidekick 3...ball still works
Yeah, more than likely the lcd cable connection is loose. That is what the white screen usually indicates.
It is fairly easy to take a apart and reseat.
Follow the guide at the link below
Fix Sidekick 3, Sidekick ID, Sidekick II White LCD Screen
Jun 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Screen not working
Lisa-
I am sorry to hear that the new sidekick 3 is not working for your son.
Is the screen white, blank, or just hard to see?
If white, then the flex cable needs to be reseated.
How to fix a blank white Screen on a Sidekick
If dark blank, then reseat the lcd assy itself and see if it works
Reseat the Sidekick 3 LCD Screen
If hard to see the screen, then the backlight is dead. A new screen is needed for that.
Replace the Sidekick 3 LCD Screen
I hope that helps
Feel free to contact me if you have questions
Dec 15, 2008 | T-Mobile Sidekick II
My sidekick 3 has sonething wrong with it.
So if the sidekick has suffered a drop or some other type of trauma, the cable for the lcd screen can come loose causing a white screen. Try the following guide to repair a white screen:
Fix a White LCD Screen on Sidekick 3
If it doesn't work, you can replace the Sidekick 3 screen assembly fairly easily. A new LCD assembly runs about 30 dollars from ebay. Here is a guide for that:
How to Replace a Sidekick 3 Screen
and here is a link to the screens on ebay:
Replacement Sidekick 3 LCD Screens for Sale
Hope that helps
Oct 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 screen is white
take the phones and have the LCD or flexcbale replaced
Jun 18, 2008 | T-Mobile Sidekick® 3 Cellular Phone
I have the same promblem!!!
if you still have warranty on the phone then just call tmobile.
goodluck but other than that the same thing happened to my sidkick but i ahd to get a new one according to an expert.
Sidekick iD screen white
take out the battery blow it 15 times then blow the back of the phone 15 times your hardest then out the battery back into place and then the loading screen would show thats what happen to me i hope it works good luck
Mar 28, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick ID blank screen
if you wiggle around the flexi cable in back of the screen it might flicker on again.
mine was faded but i was still able to see the screen .. i messed with it & it worked.
if you don't trust that way rotate the screen 90 degrees
unscrew it [MAKE SURE PHONE IS OFF!] your going to need a torx wrench, a really small 1.
take the screen off it & undo the back side of the screen & fix the cable that way.
~GL~
Jan 22, 2008 | T-Mobile Sidekick ID Cellular Phone
Black lcd screen
Does the phone still work? can you make calls? If so, yes, a screen replacement will work.
A white screen usually means no signal is being received by the screen. A black screen means the lcd back light probably died.
sidekick LCD screens
Jan 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-mobile sk3
HI im a tech at repairmysidekick.com the problem is the white screen is because of the many times you fliped the screen open or close and the flex cable which connect the screen to the phone is damaged...if you like an easy fix you can try to open the screen halfway and stick a paperclip in the pinhole on the right to soft reset the lcd if it doesnt work you can also try to remove the screws on the crome base and turn the screen upside down...check the leeds if they are gold there good if black you need to change the flex cable we can do it for you. just visit repairmysidekick.com
Dec 19, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
71 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
