Question about Brother HL 5250DN Laser Printer
Won't print after i add paper, when i try to print the machine won't print, makes a loud clicking noise as if an interior plastic part is stuck or being asked to do something it is not in position to do the paper light comes on, but i've checked and no paper is jammed or out of position
  • 6 more comments
  • Anonymous Oct 13, 2008
    Mine too! I want to smack it with a baseball bat...clicking sound, won't work...all lights blinking. Everything looks fine. :(
  • jwells498 Nov 03, 2008
    The printer is still working but as it is printing a sporatic loud click occurs
  • kala234 Dec 10, 2008
    i have this problem also, it clicks like something is stuck inside. where do i find the solution mentioned?
    thanks
  • Anonymous Dec 18, 2008
    Our lights blink red green and then yellow....any suggestions
  • Anonymous Jan 07, 2009
    The printer is making the same clicking. It's printing now but, the noise is loud and it sounds like something is broken inside the machine.
  • Anonymous Jan 16, 2009
    I tried moving the rectangular blue button, but it doesn't help.
    The only thing that seems to help is keeping the tray almost empty.
  • Anonymous Mar 31, 2009
    I have the same problem and the only way it works is to keep a low stack of paper in the tray.
  • recyclefree May 11, 2010
    The solution states: See Dumb4ever's fix for Brother HL - 5250DNT. I just tried it and it worked. Where do I find this information?
Ok, i just tried this and it works--
pull out paper drawer, in the back of the paper drawer there is a rectangular shaped blue button located just right of center. the symbol on it is a lock. this button can be pushed forward (away from you) or backwards (towards you), push it backwards towards you til it clicks in place.
return paper drawer and print.
this solved it for me-
hope this helps
Posted on Dec 10, 2008
  • 3 Answers
Check here !
http://www.fixya.com/support/t641678-paper_tray_noise
Posted on Mar 25, 2009
Posted on Oct 22, 2008
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Loud clicking noise when attempting to print
Try removing the ink catridges and checking them for any damage like leaking ink. Then replace them and try to print. Also, make sure there is nothing stuck in the paper feeding tray.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Hp psc 2210 printer jam
your printer need to be opened and check for any lever is struck or dislodge, it will be better if you send it for servicing
May 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Apr 13, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Brother HL 5250DN Laser Printer Logo
952 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
