Question about Lexmark Office Equipment & Supplies
I just installed a Lexmark X4530 printer/scanner. Every other page I try to scan, I get the message 'Scan Request Failed'. It seems to be totally random, no change to settings or the page being scanned. This is a replacement to a Lexmark 5000 series printer/scanner, which did the same thing, only worse. Does anyone know why this is happening? I thought Lexmark was a more reliable product.
  • 1113 Answers
SOURCE: canon MP780 wont scan
Download and reinstall scanner software and scan driver
Posted on Nov 01, 2007
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
  • 5 Answers
SOURCE: i cant scan my pictures... i have lexmark x4530
Right click and open the installation disk and look for 'applications\setup' and install it.
If you donot see the same, double click on the disk [left] select 'install\custom install' and select 'productivity studio' and install it, it should work.
The last option is to reinstall the whole drivers.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: where do i get a
Go to the Lexmark Imaging icon (located on the taskbar) and look to the left and down the bottom. You will see Network Settings, click on the "view or change network settings." When you get in, uncheck the "I WISH TO REQUIRE A PIN TO SCAN TO MY COMPUTER" and then press OK. This will remove the pin setting from your scanner. Lexmark technical support just did that for me, now my printer does not ask for a pin number.
Posted on Mar 30, 2009
  • 19396 Answers
SOURCE: My Lexmark X2350 all in one printer wont scan
Reinstalling drivers often solves this kind of problem.
Here the driver download page for this printer: download
a driver?
Posted on May 17, 2009
I need OCR folder for lexmark x4530
You can download and install the Lexmark OCR scan software using the installation disc that came with your printer only. The software is not available for downloading online.
If you lost the disc, please contact Lexmark Technical Support Center to request for one. Thanks.
Nov 11, 2011 | Lexmark X4530 InkJet Printer
I was able to scan to my computer four pictures without any problems. When I tried the fifth, I get a "scan request failed" repeatedly. Nothing changed between the computer and the printer. ...
What is the status of the WiFi light on your printer? Try to check if your printer is still connected to your wireless network by printing the wireless network settings. How to Print the Network Settings Page on the X3500 and X4500 Series Inkjets; a Brief Explanation of its Values. Check the SSID and the IP address of the printer and see if it's the same as your network.
You can also try to relaunch the Lexmark Wireless Setup utility to connect to the printer again.
May 28, 2011 | Lexmark X4530 InkJet Printer
Error message Scan Failed
how take back off x4530jet printer-hp-got jamed paper out now wont feed paper
Mar 05, 2011 | Lexmark X4530 InkJet Printer
Ocr missing in folder. I can not scan text as PDF files
The Lexmark OCR scan software is available in the installation disk. Just insert the disk in your computer and execute the driver to install the software. It's not available for online download. If you lost the disk, contact Lexmark technical support. Thanks.
Oct 07, 2010 | Lexmark X4530 InkJet Printer
I want to scan a document. I click Scan Mode. The printer responds, "Retreiving Application List," then "Cannot Retrieve Application List."
A problem occurs with your scan driver. You will need to reinstall it to correct the problem.
Another way to scan is to use the scanner option in your computer. Go to Control Panel. Double click the Scanners & Cameras icon. Feed your documents in the printer before starting the scan process.
Try it.
Please give this answer a four thumbs up rating it this help you.
Thank you for using Fixya
Sep 12, 2010 | Lexmark X4530 InkJet Printer
I'm trying to scan a picture to my computer,but can't get it to work
The only way I got my Lexmark to scan, was to install the CD that came with it. It installs a program called "Lexmark Imaging Studio". That's where the scan will be transferred to from the printer.
To scan: Press the Scan Mode button, and then the check mark in the middle of the buttons. Then to activate the scan, press Start Color or Start Black to start the scan. With the Imaging Program installed, it will automatically come up and display the scan, where you can scan more or save or print the scan. I have the X4530 Lexmark all-in-one, but the program should be the same, or similar. Good luck, hope this helps.
Apr 18, 2010 | Lexmark X4650 InkJet Printer
I installed the Lexmark x4530 and continue to get
Usually a cable is not hooked up or the printer port is not enabled.
If it uses a USB port it should auto detect the port.
If this is the case you will need to download a new driver from the Lexmark site that matches your operating system and install it.
Mar 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
157 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
