Question about Samsung PCL5415RB 54" Rear Projection Television
Samsung sp43w6hl rear projection tv
On both sides of the screen about 4/5 inch's the picture has a blue red green shadows and the picture is slightly out of focus
SOURCE: Suddenly Green focus shift off and cann't be able to autoalign
There is a Convergance board that needs to be replaced.there is no way of fixing that problem without replacing that board first
Posted on Feb 22, 2007
  • 1153 Answers
SOURCE: blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Posted on Nov 25, 2007
techman007
  • 1112 Answers
SOURCE: I have an akai rear projection big screen tv that
Replace the Blue convergence IC, But you should consider replacing both of them, because if one has failed then the other is likely to sooner or later. They are large Black IC's mounted on a Metel Heatsink. I believe on this model the board is in the middle of the unit. Before you replace check the solder connection on the Ic's first you might just have a few cold solder joints, if not then replace both IC's
Posted on Dec 04, 2009
barbu51
  • 566 Answers
SOURCE: Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Posted on Dec 07, 2009
SOURCE: i have a samsung 47 inch rear projection w/self
The blue is caused by the RGB gun alignment. Green is a fixed gun and Red and Blue are adjustable. In my Mitsubishi, the guns are motorized and can initially be adjusted (course) with the remote. There are more detailed adjustments that can be made if you purchase the service manual. I paid approx $19.00 on line 3 years ago and it is a complete manual. Unfortunetly I don't remember the site. To do a complete alignment, there are steps to take: starting with entering a code using the remote to enter the setup. To make a long story short, I had my tv aligned 3 or 4 times over 5 years under the extended warranty. After watching the tech, who was good, but under time constraints, it was clear that most anyone could do it if they could read and follow instructions.
Posted on Mar 05, 2010
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
272 people viewed this question
Henry  Thomas
Henry Thomas
