Question about Acer Aspire 5500 5570-2609 Laptop
Pxe mof exiting pfe rom problems on acer laptop operating system not found.please assist cannot boot up
    Scholar:
  • 63 Answers
Go into the Bios and disable LAN boot.. usualy hit f2 or del as soon as it is booting up.
If this computer was working before.. then it cannot find the hard drive or anything to boot from and has gone to another place to try to boot.
Best wishes..
www.techvisitor.com
Posted on Oct 31, 2008
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
Please I have a question in relation to my acer aspire laptop5536-5883, when i switch on my laptop, it says PXE-E61: Media test failure, check cable, PXE-MOF: existing broadcomm PXE ROM. OPERATING SYSTEM...
PXE is looking for an OS on/over a network...you need to tell the PC to boot from your harddrive or CD...if the harddrive is bad/blank you need to (re)install windows...
Feb 14, 2011 | Acer Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
I have an emachines e620 and when i switch my computer on it says pxe-e61 media test failure, check cable and it also says pxe-mof exiting pxe rom operating system not found help would be great
Go into set-up and change the boot order to the hard drive you have your operating system on... then cd-rom. you may actually want to start with your cd-rom as it makes it easier when you are installing an operating system.
robert
Sep 04, 2009 | eMachines E620-5885 Notebook
First enter your bios setup by pressing F2 when your computer starts. Find the section which sets the boot device order. Change the first boot device to CDROM. Save the settings and exit bios. Now put your recovery CD in cdrom drive and see if it runs.
Let me know if it does not work
Nov 26, 2008 | Acer Computers & Internet
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Acer aspire 5630 wont boot up
it may be that the harddrive had broked, or is not properly mounted. Try removing it and then reatach it. what operating sistem do u use ?!
also try booting with a linux live cd and see if it can accesc the hard drive, if it cant, than thatşs u're problem. If it can, than u have to find out what PXE-E61 is (what component), and then test it (i presume is the hard drive or the optical unit)
May 01, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
265 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
