Question about HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop
Install sata drives on abit av8 motherboard (vista home)
I have decided to upgrade hard drive and dvd rom to sata. i have set bios but no drives are detected. tried a total reinstall using ide rom but still no hard drive. once vista is installed on ide drive sata dvdrom is working but when i boot with sata hard drive attatched aswell there is only ide hard drive. Q. can this board boot from a sata drive/ can it handle a 250gb drive/would i be better buying another board.
  • 7 more comments
  • heckius Sep 28, 2008
    Yes i installed them when i tried installing vista went through install but still no drive. Then i have installed them in vista. when Pioneer 20x 30708 internal dvdrw is connect with 80gb ide hard drive, device manager shows device to be working fine, when i connect HITACHI 250GB SATA HDD the device is shown with a yellow exclamation with (this device canno start (code 10)
    thanks joed tried that but no joy. i have ide hard drive,usb pen drive, sata dvdrom and sata hard drive connected but in disk managment there is only ide drive and pen drive.
    no neither sata drives are present in bios and "sata raid rom is set to enabled" this is the only reference to sata in the bios
    yes it does scan and it reports dvdrom as non raid device but still doesn't see hdd, i have tried swapping all connections with rom and still same results, rom works perfectly fine until i connect hdd.
    no jumpers on either rom or hd i have set them both on seperate cables
    also both drives are new out of packet and never been able to do anything with hdd
    i was starting to think that myself .. thanks a million for trying
  • JDTec
    JDTec May 11, 2010
    DiD you install the SATA drivers?
  • Anonymous Mar 18, 2014
    Which SATA connectors should be used for 6 GB/s drives?
  • HP Master
  • 4,338 Answers
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Posted on Sep 28, 2008
  • 3 more comments
  • JDTec
    JDTec Sep 28, 2008
    In BIOS, do you see the SATA drive. Is this option turned on?
  • JDTec
    JDTec Sep 28, 2008
    Do you see the unit scan for the SATA drives on boot up? It should since the option is enabled in the Bios.
    Move the seial cable to a different connector, see if it's the connection.
  • JDTec
    JDTec Sep 28, 2008
    I know that SATA drives do not need jumpers for drive selection, but just for grins, check the CD-Rom and see if it has a jumper. It may be conflicting.
    Is the SATA HD partitioned?
  • JDTec
    JDTec Sep 28, 2008
    HD may be bad... after all you have done, that may be the reason.
  • JDTec
    JDTec Sep 28, 2008
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Cannot get sata drives reconized on my abit av8 motherboard.
i required mother board drivers for asus
p4vp-mx
Jun 09, 2009 | Abit AV8 Motherboard
ABIT AV8 not reading SATA ASUS DVD Burner
you should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given there.by that you can even find out the problem in *********** board if any. if you are convinced please rate me
Sep 22, 2008 | Abit AV8-3rd Eye Motherboard
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
http://www2.abit.com.tw/page/en/download/download_bios.php?pMAIN_TYPE=Motherboard&pSUB_TYPE=Socket%20754
Dec 30, 2007 | Abit KV8 Pro Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Loading xp home edition
I can try and suggest you check the cables from you CD-ROM, any sort of damage the CD might have. Or then again, if your Hard Drive is SATA connected, then you'll need to load the SATA controler (F6 on the windows instalation) And, in last case, either upgrade your bios or try a different CD-ROM drive unit. But I would defenatly put my money on the cables.
Sep 23, 2007 | Abit KV7-V Motherboard
HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop Logo
880 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
